A-GPS - doubt
Dieses Thema im Forum "General Discussions" wurde erstellt von JATG, 20. September 2012.
  1. JATG
    JATG New Member
    17. September 2012
    Hiphone 4GS
    I'm about to buy a mobile phone white label that says owning just "A-GPS" (not internal GPS).
    If I install a browser like CoPilot and respective maps on sd card, I can navigate offline?
    In other words, my question is whether the system with A-GPS it is possible to browse offline, without spending net traffic, since the browser and maps are on the respective memory card.
    Or this system always needs to connect to the network?
    Thank you.
  2. reddwarf0815
    reddwarf0815 Member
    21. August 2012
    Lenovo P780
    A-GPS is just a network based support for real GPS. A-GPS needs a working network connection.
    So you can not use it offline at all.
    Regards,
    Mario
  3. JATG
    JATG New Member
    17. September 2012
    Hiphone 4GS
    And if I browsing about 60 minutes will spend 60 minutes of GPRS traffic?
  4. ColonelZap
    9. April 2008
    Xiaomi Mi4
    If a phone has A-GPS that SHOULD indicate that "real" GPS is also there. Nobody makes a phone with JUST A-GPS, A-GPS without real GPS doesn't make any sense.
  5. reddwarf0815
    reddwarf0815 Member
    21. August 2012
    Lenovo P780
    This is not true. Some cheap phones have A-GPS installed but lack the real GPS-Sensor. Chinese call this GPS ready......
  6. ColonelZap
    9. April 2008
    Xiaomi Mi4
    Well, I've never seen one with just A-GPS. A=assisted, so what should be assisted if GPS is not there?
  7. reddwarf0815
    reddwarf0815 Member
    21. August 2012
    Lenovo P780
    Star A-3000 for instance.
    A-GPS but no GPS receiver.
    It's meant for external GPS devices.
    Regards,
    Mario
  8. ColonelZap
    9. April 2008
    Xiaomi Mi4
  9. reddwarf0815
    reddwarf0815 Member
    21. August 2012
    Lenovo P780
  10. JATG
    JATG New Member
    17. September 2012
    Hiphone 4GS
  11. duffy-31
    duffy-31 Well-Known Member
    3. Februar 2010
    I don't think so, same Phone in other Shops - different Specifications including GPS.
    In addition, the CPU is outdated.
  12. JATG
    JATG New Member
    17. September 2012
    Hiphone 4GS
    In some shops says GPS built-in in other shops says A-GPS.
    I don`t know if is just A-GPS or GPS and A-GPS...
    What you think?
  13. duffy-31
    3. Februar 2010
    Probably real GPS.
    But Who cares ? It's not worth to buy.
