Anleitung Chang Jiang p5 / THL V 11 root, upgrade 2.3.6 to 4.0 Mtk6575
Dieses Thema im Forum "Android Phones Tutorials" wurde erstellt von twinko, 19. Mai 2013.
  1. twinko
    twinko New Member
    1. Oktober 2012
    Thl v11
    beziehungsweise
    chang jiang p5
    Sorry for all mistakes, my english is very bad and im realy tired ;)
    1 thing doesnt work: i cant use "Text to speech". If u finde a solution, let me know.
    Ich bin deutsch, werde aber nicht alles noch ins deutsche übersetzen! bitte nutzt google translate!
    I deny any responsibility, and all you will perform - you perform on your own !!!!!!!
    • Backup all your data!!! make shure battery is nearly full and close backcase every time. battery fall off at this process=phone brick
    • ROOT 2.3.6
    1. Download V11_CJ_p5_root.zip ( just-life.de/twinko/rootthlv11/V11_CJ_p5_root.zip)
    2. Copy it on your sd card in the root folder (DONT extract it!!!)
    3. Reboot to recovery (power+vol- on system startup or in 2.3.6 settings "about the phone" --> "Reboot Recovery")
    4. Now u are in the recovery menue, press vol button to navigate and power button to confirm
    5. Go to update from sdcard (or something like that, should be second from top)
    6. Search for V11_CJ_p5_root.zip and confirm with power button
    7. Reboot phone
    8. Now u have root rights!
    • Update 2.3.6 to 4.0.x (at this point u will loose all data on phone)
    1. I hightly recommend to save all your date with titanium backup and dont miss your contacts ;)
    2. Download the newest rom version 4.0.4 (2012-12-14) from https://disk.yandex.com/public/?hash=cGq0GWE+FBvT4SYnMX3OPDsXXuwSkH/Xljs7yTfea50= , if this link doesnt work visit http://forum.china-iphone.ru/thl-v11-chang-jiang-p5-t19491.html go to ПРОШИВКИ --> Прошивки с офсайта and download the latest version
    3. Download mtkdroid tools (http://dfiles.eu/files/qf7cir79b)
    4. Download sp flash tool (http://forum.xda-developers.com/showthread.php?t=1982576)
    5. Install driver like described here: http://chinamobiles.org/showthread....-Treiber-Installation-Test-CWM-Recovery-Flash
    6. Download twrp http://files.china-iphone.ru/687twrp_v2.4.4_thl_v11_by_sekil_mod_nvram.img
    7. Download http://goo.im/gapps/gapps-ics-20120429-signed.zip
    8. Connect phone to pc and turn usb debugging at phone on
    9. i recomment to reset your phone to factory (in recovery mode)
    10. Turn phone off, unplugg from pc and remove battery for 10 sec
    11. Start sp flash tool
    12. Load the scatter.txt from the downloaded 4.XX Rom version (MT6575_Android_scatter.txt)
    13. Mark all files below, and press download
    14. Plug phone to pc but dont turn on!!
    15. Download will start at sp flash tool
    16. WAIT TILL EXTRA WINDOW OPEN (one with a green circle)
    17. DONT START PHONE! Unplugg battery for 1 min!!!!!!!
    18. Start phone and here we go u have android 4.XX
    19. Start mtkdroid tools and root phone again
    20. Copy gapps-ics-20120429-signed.zip to your sd card
    21. Shutdown phone and remove battery
    22. Start sp flashg tool again load scatter and double klick on recovery
    23. Search for the twrp file (twrp_v2.4.4_thl_v11_by_sekil_mod_nvram.img)
    24. Unmark all other positions (without recovery ;) )
    25. Press download (in sp flash tool) and AFTER that battery back to phone and plug it to pc (phone still turned off)
    26. WAIT TILL EXTRA WINDOW OPEN (one with a green circle)
    27. DONT START PHONE! Unplugg battery for 1 min!!!!!!!
    28. Start phone to recovery mode (Reboot to recovery (power+vol- on system startup or in settings "about the phone" --> "Reboot Recovery")
    29. Install gapps-ics-20120429-signed.zip
    30. Reboot phone
    • Last thing: there are some permissions missing we need to install all apps on android market:
      Easy way:
    • Reboot to recovery (power+vol- on system startup or in settings "about the phone" --> "Reboot Recovery")
    • now u see twrp, navigate to Advanced and klick "Fix Permissions" and swipe to confirme
    • restart phone
    • if this doenst help try the manual way, writen below
    Manuale Permissions
    • install the Es data manager: https://play.google.com/store/apps/details?id=com.estrongs.android.pop&feature=order_history
    • download http://forum.china-iphone.ru/download/file.php?id=37850
    • either u put the following lines in a file or u write everything on your phone by yourself
    • <feature name="android.hardware.camera" />
      <feature name="android.hardware.camera.autofocus" />
      <feature name="android.hardware.camera.autofocus-flash" />
      <feature name="android.hardware.camera.front" />
      <feature name="android.hardware.wifi" />
      <feature name="android.hardware.touchscreen" />
      <feature name="android.hardware.touchscreen.multitouch.jazzhand" />
      <feature name="android.hardware.sensor.light" />
      <feature name="android.hardware.sensor.proximity" />
      <feature name="android.hardware.location" />
      <feature name="android.hardware.location.gps" />
      <feature name="android.hardware.location.network" />
      <feature name="android.hardware.location.provider" />
      <feature name="android.hardware.sensor.compass" />
      <feature name="android.hardware.sensor.accelerometer" />
      <feature name="android.hardware.bluetooth" />
      <feature name="android.hardware.microphone" />
      <feature name="android.hardware.screen.portrait" />
      <feature name="android.hardware.screen.landscape" />
    • now link phone to pc, start usb connection and copy the downloaded files to your sd card (i recommend to create a new folder AND now we need them extracted not the .rar !!)
    • start es data manager, go to "root-explorer"--> embed AS R/W --> both buttons on RW --> OK
    • overwrite to files to /system/etc/permissions/
    • after that go to /system/etc/permissions/handheld_core_hardware.xml and edit this file via ES Note-editor
    • now search for <permissions> <!--
    • replace everything between <!-- and --> with the posted lines <feature name="an.............
    • press back button and save
    • go to app managament clear cash of google play store
    • Restart phone
    Hint:
    u wonna use your apps in your language: install morelocal 2 (https://play.google.com/store/apps/details?id=jp.co.c_lis.ccl.morelocale&hl=de)
    AND BE HAPPY as Sh/%$ u found this tut. to find out takes me round 1 week. russian and chinese are realy difficult languages
  2. twinko
    twinko New Member
    1. Oktober 2012
    Thl v11
    beziehungsweise
    chang jiang p5
    update: jetzt geht bei mir alles!!
    hrhr........ fast
    außer Text-to-speech aber naja kann man mit leben.
