barcode scanner app for pinphone 3gs
Dieses Thema im Forum "General Discussions" wurde erstellt von markb, 13. Februar 2011.
  1. markb
    markb New Member
    9. Februar 2011
    pinphone 3gs 4gb
    hi, is there a barcode scanner app for the pinphone 3gs ? i have tried several java .jar file scanners and none seem to work ,even tried unpacking an apk scanner and converting it ,but gave up ..... thanks mark
  2. ColonelZap
    9. April 2008
    Xiaomi Mi4
    I don't thing so, I'd be surprised if Java on that phone would work in combination with the camera.
  3. Ciney
    Ciney New Member
    22. September 2010
    Kiphone 4GS
    WHAT?
    You tried to convert an APK program into a java *.jar-file? And you could install it on the pinphone but only the scanner didn't work?
    I've read that it is possible to convert java files into APK Programs for Android cellphones...but the other way round???
    would be happy if you explain what you've done :)
  4. markb
    markb New Member
    9. Februar 2011
    pinphone 3gs 4gb
  5. duffy-31
    duffy-31 Well-Known Member
    3. Februar 2010
    Beside all other Needs, without Autofocus it won't Work.
  6. Ciney
    Ciney New Member
    22. September 2010
    Kiphone 4GS
    Yes i found this link too, but this is only a way for decompiling the apk-files into single files to manipulate them. I've just tried to convert an Adobe Reade and some other small programs, but it doesn't work, phone says only "jar-file is wrong". Understandable, all the program design and so on is in the other files, not in the classes.dex which you can convert to *.jar-file....
