CiPhone C6 software questions
Dieses Thema im Forum "General Discussions" wurde erstellt von mondy_aqua, 30. Mai 2010.
  1. mondy_aqua
    mondy_aqua New Member
    30. Mai 2010
    Ciphone C+6
    Hello sir
    How are you doing ?
    It's Ahmed from Egypt
    Can you help me sir .. :)
    I have bought this model of Ciphone C6+
    http://www.solomobi.com/viewproduct.asp?pro_id=3542
    and I'm looking for any software for this mobile
    and if i found the programs how can i install it on the phone
    And i thank you soooo much
  2. duffy-31
    duffy-31 Well-Known Member
    3. Februar 2010
    Hello Ahmed, what programs are you looking for ?
    You can find a large amount of programs with google, or at xda developers, pocketpc, etc
    Most common is the .cab format, download the file to your pc, copy it to the storage card and open the file.
    Your device will ask you in which directory you want to install, for the most, storage card is best choice, keeps the system fast and slim.
    Further questions welcome !
