Elephone P8000 Review
Dieses Thema im Forum "General Discussions" wurde erstellt von zijin_cheng, 20. Oktober 2015.
  1. zijin_cheng
    zijin_cheng Active Member
    8. Februar 2015
    THL 5000
    Cubot X9
    Hey guys, what's up, ZI Jin Cheng here and this is the review of the Elephone P8000, Elephone's flagship device. I'm very impressed with this device and the only two reasons why I'm not using it as my daily driver is that it is too big and isn't supported by my carrier.
    Specs:
    5.5" 1920x1080 IPS Display
    MTK6753 Processor
    3GB RAM, 16GB ROM
    13MP, 5MP Camera
    4000mAh Battery
    2G: GSM 850/900/1800/1900MHz
    3G: WCDMA 900/2100MHz
    4G: FDD-LTE 800/1800/2100/2600MHz
    thor2001 sagt Danke für diesen hilfreichen Beitrag.
  2. UncleChicken
    UncleChicken Member
    7. September 2011
    xda neo
    Thanks for the reviews.
    Is it a built-in battery? Is it easy to change?
  3. zijin_cheng
    8. Februar 2015
    THL 5000
    Cubot X9
    Yes the battery is non removeable and I don't think it is very easy to change.
