  2. Information ausblenden
english rom for T5358+
Dieses Thema im Forum "General Discussions" wurde erstellt von binary_dreamer, 11. Mai 2010.
  1. binary_dreamer
    binary_dreamer New Member
    11. Mai 2010
    T5358+
    Hi.
    Sorry for the english, but this is the only forum that i have found for T5358+.
    I would like to ask if there is an English ROM with WM6.5 for my mobile?
    i have tried to do a hardspl but someone told me that chinese clones do not do hardspl.
    i would appreciate any help available.
  2. Petteri
    Petteri Well-Known Member
    13. August 2009
    Tablets: Acer Switch 10
  3. binary_dreamer
    11. Mai 2010
    T5358+
    two questions:
    -will that work for my T5358+?
    -any ideas of a nice rom with WM 6.5?
  4. Petteri
    13. August 2009
  5. binary_dreamer
    11. Mai 2010
    T5358+
  6. Petteri
    13. August 2009
  7. binary_dreamer
    11. Mai 2010
    T5358+
    I have tried the link that you suggested and the mobile cannot load the wm rom. i do not mind if it is in german. i was hoping to use SPB and use any other language.
    The model that i do have is the one that you said, but with older OS (wm 6.1) and it it the T5358+.
  8. Petteri
    13. August 2009
    I asked my seller for an new english wm 6.5 rom for your phone....if i received it, i will upload it here and you can test it! you know, you can`t flash direct from your phone..you have to use IDT for flashing! you know this?!
  9. binary_dreamer
    11. Mai 2010
    T5358+
    Hi.
    thanks a lot for your quick reply.
    I am using the IDT software through my PC.
    Is there any way i could post the phone and someone flash it, with a cost of course.
  10. Petteri
    13. August 2009
    i will do this....please sent me a pm for getting more information....
  11. Petteri
    13. August 2009
    http://depositfiles.com/files/kv57wh317
    latest english WM 6.5 ROM for T5358+
    must be flshed with IDT:
    Instruction for flexing:
    1.download software IDT and ROM file,install the IDT,password is hisilicon, after that, press enter
    http://p5.images22.51img1.com/6000/qq471519374/5050a5c9c393456b6cd06a6653f23435.jpg
    2.when the interface shown up as below,on "Misc",only select first four options,ignore the others.
    select the square behind Image File,select the location of your ROM file, then press enter.
    http://www.m44.com.cn/attachments/month_0912/09121420303b0c4a02d7e66f8f.jpg
    3.If you IDT is new version, it will pop up a confirm textbox, click ok to confirm it.
    http://p7.images22.51img1.com/6000/qq471519374/75b0cb5808202489eb62642812114fe2.jpg
    4.You may also see a confirmation step like this, select "gsm"
    http://p8.images22.51img1.com/6000/qq471519374/89df46bea7b457f602ff75fb90bcd596.jpg
    5. Make sure the cellphone is completely off, then hold the "dial key" and the "hang up key", at the same time, press the "power key". Then a interface will come out as below(some model is hang up key+volume up key+power key):
    http://pf.images22.51img1.com/6000/qq471519374/f5e4e1f1070b22ba1b3251a602766208.jpg
    7.connect your phone and your pc by USB cable,the pc will automatically find the driver and start downloading the ROM to your cellphone as shown below,when it is 100% finished,it will automatically restart, and you are ready to rock!
    http://pe.images22.51img1.com/6000/qq471519374/e5d359e5c4918faaff442267a07181ed.jpg
