FOG N4, Advanced S-Pen, MTK6592 1.7GHz, 5.7" IPS HD OGS, IR Sensor, OTG, 4D Air Gestures, Heart rate
  1. s7yler
    s7yler Youtube.com/s7yler
    26. Februar 2014
    OnePlus 5 / ZUK Z2 Pro / Xiaomi Mi5 / Elephone P9000 / Bluboo S8 / Doogee Mix / VKWorld Mix Plus / UMIDIGI Crystal / UMIDIGI Z1 Pro / Maze Alpha
    Unboxing
    Full Review
    Von hier: http://efox-shop.com/fog-n4-mtk6592...-bildschirm-android-44-3g-smartphone-g-298380
    INDEX/Video Review Inhalt:
    Specifications
    Phone design
    2.5D curved glass design
    Lockscreen
    The User Interface / Launcher
    UI scroll speed
    Viewing angles
    Some words about the screen
    The hardware buttons with backlight
    Offscreen gestures & double tap to wake
    4D air gestures
    The quick toggles
    Wifi signal & network reception, 3G
    The sidepanel
    Multitasking overview in Lollipop style
    Multiwindow sidebar (not real multiwindow)
    The FOG N4 compared with the Landvo L600S
    The settings
    Language
    Storage
    About phone, android version & wireless update?
    Camera app
    Camera test
    Frontfacing camera test
    Flashlight LED test
    S-health app, Heart rate app test
    ZaZa remote IR blaster app
    Videoplayer & popout feature
    Advanced S-pen test
    USB OTG test
    Music test over Bluetooth (with OTG, USB stick)
    Music test with internal phone speaker
    Info about using headphones with the phone
    Test call, sound & proximity sensor test
    Test of original Note 4 battery & backcover
    Running some different test apps!
    WiFi & speedtest
    Androbench read/write speedtest
    GPS test results
    Antutu benchmark v5.6.1 results
    Sensors
    Notification LED colour test
    3D gaming racing test
    Multitouch screen test, 10 points!
    Root checker
    Link2SD storage check
    CPU Identifier info
    Playstore, Browser & Youtube test
    Check of phone weight, battery weight & phone thickness
    Pros & Cons
    Kamera Samples/Tests
    ( https://plus.google.com/photos/100582382505207418108/albums/6122864809660919697 )
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    FOG = FOCUS ON GEEKS! :scratch_one-s_head:
    Technische Daten:
    - 5,7-Zoll-Bildschirm, 1280x720 Pixel IPS HD OGS (10 Point Multitouch Schirm!)
    - MT6592 1,7 GHz Octa-Core
    - Dual Mic Noise Reduction
    - Dual Micro-SIM
    - GSM 850/900/1800/1900MHz, WCDMA 850/1900/2100 MHz
    - 1 GB RAM + 16 GB ROM
    - 13 MP Hauptkamera + 5 MP Frontkamera (Kameras sind okay und brauchbar)
    - Unterstützt Advanced S-Pen Features (ganz gut gemacht, der S-Pen ist aber nicht so schnell)
    - CNC-Aluminium-Zink-Aluminium-Rahmen
    - Android 4.4.2 KitKat-System
    - IR-Fernbedienung (funktioniert sehr gut)
    - Double Tap zu wecken
    - Kopfhörer-Sound Qualität ist gut (aber nicht so laut!)
    - 4D Air Gestures (alle 4 Richtungen)
    - Herzfrequenz-Sensor (ich glaube fake!)
    - OTG USB On The Go
    - Notifikation LED (RGB) und Touchbuttons mit Hintergrundbeleuchtung
    - Gorilla-Glas (Ich bin im Zweifel, ob es echt ist)
    - Unterstützt auch drahtlose Aufladen (jedoch "Charger pad" NICHT im Lieferumfang enthalten!)
    Cons:
    - Verarbeitungsqualität nur wie die 1:1 Note 4 klone, wirkt billig!
    - Nur HD Bildschirm, kleine Pixels kann man ganz nah erkennen!
    - Der Helligkeit ist nicht 100% stabil auf mein FOG N4.
    - Original Note 4 Akku passt nicht drin, Cover-Rückseite geht, aber die Kamera ist rund statt eckig!
    - Sehr wenige Sensoren!
    - 2 Akkus sind mit, aber die sind klein! wahrscheinlich nicht viel mehr als 1700-1800mAh Max! (wie die Klone)
    - Nach meiner Persönlicher Meinung viel zu teuer!
    Ich kann das FOG N4 aufgrund dieser von mir kritisierten Punkte, nur bedingt empfehlen!
    s7yler's Bewertung ***** (2 von 5 Sternen)
    Zuletzt von einem Moderator bearbeitet: 12. Januar 2018
  2. Binser
    Binser Well-Known Member
    23. Mai 2013
    Xiaomi Redmi 5+, Mi Max 2, Mi Max, Lenovo K3 Note, Blackview Alife S1, Sony Xperia X8, Nook ST, Fire TV, MK809 Plus, MK808B Plus
    Gibt's jetzt für 170 USD
    http://www.geekbuying.com/item/FOG-...-16GB-13-0MP-5-0MP-3G-GPS---White-341110.html
    Würdest Du es für diesen Preis jetzt empfehlen? Ich hatte den Eindruck, Du hast das Phone hauptsächlich wegen des Preises abgewertet.
    Übrigens schreibst Du: "Dual Mic Noise Reduction". Hat es wirklich 2 Mics für Stereo Aufnahmen und funktioniert die Noise Reduction tatsächlich wenn man in lauten Umgebungen telefoniert?
    Was für einen anderen Note 4 Klon würdest Du empfehlen (inkl. IR und S-Pen)?
  3. s7yler
    26. Februar 2014
    @Binser
    Kenne leider keine Alternative mit IR und advanced S-pen. Naja ich finde es sollte 145 USD kosten, nicht viel mehr weil so vom Verarbeitungsqualität wirkt es ein bisschen Billig finde ich. Die Noise Reduction ist für mich schwer zu einschätzen, aber der Ton ist schon viel besser als bei mein Note 3 1:1 Klon. Aber nicht wie auf die teuren Brands.
  4. Binser
    23. Mai 2013
    Danke für Deine Antwort. Darf ich noch mal nachfragen:
    "Wirkt" die Verarbeitungsqualität einfach nur billig (wegen dem Aussehen, den Materialien) , oder ist das Gerät tatsächlich schlecht verarbeitet, so dass die Funktionalität oder Haltbarkeit beeinträchtigt ist?
  5. s7yler
    26. Februar 2014
    Verarbeitung ist eigentlich ok, Wirkt aber billig wegen Aussehen und den Materialien.
  6. Daemonarch
    Daemonarch Chiclone-Lover
    20. Dezember 2011
    No.1-N3, Doogee DG2014, Samsung Galaxy S1+, S2, Note1, Note2...
    "Billiger" als vom HDC Note4 1:1?
  7. s7yler
    26. Februar 2014
    Ungefähr gleich wie die 1:1 Klone.
  8. Daemonarch
    20. Dezember 2011
    Weil, nach meinem "Gefühl" (vergleich im Media-Markt), wirkt der HDC-clone kaum weniger wertig als das Original.
  9. Binser
    23. Mai 2013
    Das 1 GB ROM ist schon ein bißchen schwach. Kann man den nicht umformatieren?
    Ansonsten müßte man halt Link2SD oder Mounts2SD verwenden.
  10. Daemonarch
    20. Dezember 2011
    Kann man, ist halt nicht komplett risikolos - gibt hier auch nen schönen Thread zu.
    Wenn man ein funktionsfähiges Backup und/oder die Stockrom parat hat, ist es recht risikoarm.
    Muss man sich halt akribisch einlesen.
  11. Binser
    23. Mai 2013
    Thread für das Handy oder den Prozessor?
  12. Daemonarch
    20. Dezember 2011
  13. mipri
    mipri Mit Daxian T32 hats angefangen
    18. April 2009
    H801, SM-N900, DG550, Leagoo Lead1, Axgio N1
    Gibts jetzt als Vervan Vnote für 99$. Baugleich mit dem FOG. Ich glaub auch ohne LTE kann man da nicht meckern. Hab mir eines geholt. Dank guter partitionierung genügend Platz für Apps. IR und Pulsmesser funktionieren ohne Probleme.
