Galaxy S4 Clone Touchscreen Problem!
Dieses Thema im Forum "General Discussions" wurde erstellt von maiconmassa, 23. Oktober 2014.
  1. maiconmassa
    maiconmassa New Member
    23. Oktober 2014
    After a long search, finally a speech que forum on Chinese clones!
    I recently bought a copy of Galaxy S4, most unfortunately, he provides the following problem
    I wonder if some solution exists, and if so, I ask you to help me !!
    Thank you!
    Olá pessoal ...
    Depois de uma longa procura, finalmente, um discurso that fórum sobre clones chineses!
    Eu comprei recentemente uma cópia do Galaxy S4, a maioria, infelizmente, ele fornece o seguinte problema
    Gostaria de saber se alguma solução existe, e se assim for, peço-lhe que me ajude !!
    Obrigado!
    Hardware: MT6589 (UNIVERSAL5410 (exynos5) é errado!)
    Modelo: GT-i9500
    Número de compilação: ALPS.JB2.MP.V1.26
    Construir data UTC: 20131015-111301
    Android v 4.2.9
    Baseband v: MOLY.WR8.W1248.MD.WG.MP.V23, 2013/07/25 04:17
    V Kernel: 3.4.5 (zhanghongqiang @ Yaocong desktop) (versão gcc 4.6.x google 20120106 (pré-lançamento) (GCC)) # 1 SMP Tue 15 de outubro 19:10:49 CST 2013
    Uboot construir v: -----
    Controlador de LCD IC-1 nt35590_hd720_dsi_cmd_truly
    Download link de backup não MTKdroid corrigir!
    https://www.dropbox.com/s/ihytkd0qp3vew8d/Backupmtk252TOUCHWRONG.rar?dl=0
    Zuletzt von einem Moderator bearbeitet: 23. Oktober 2014
  2. rWx
    rWx Well-Known Member
    24. April 2012
    Xiaomi Max 3/64
    Huawei Mate 7
    Huawei Mate S
    Xiaomi Redmi Note
    @maiconmassa, please write in english :) I have moved your contribution.
    Maybe you have wrong display driver? Did you flashed another firmware before you made a backup?
    Ora und maiconmassa sagen Danke für diesen hilfreichen Beitrag.
  3. maiconmassa
    23. Oktober 2014
    RWX Thanks for giving the importance to my problem ..
    I did the backup for MTKdroid Tools 2.5.2 before flashing the ROM spoiled everything ... : / But when the backup does not flash back to normal : ///
    the ROM I blinked and gave problems 20131028_JK_S8977A_V402_ROOT_LDv0502
    and here are some specs on the phone http://specdevice.com/showspec.php?id=6d40-a18b-47c4-68bb3dbb9901
  4. rWx
    24. April 2012
    Xiaomi Max 3/64
    Huawei Mate 7
    Huawei Mate S
    Xiaomi Redmi Note
    This problem i had also been in a similar model. Please look for information to this thread, and ask @Ora for correctly ROM or display driver (uboot image). I think it is the same model? :)
    Unfortunately file does not exist. @Ora, it could be this ROM?
    maiconmassa sagt Danke für diesen hilfreichen Beitrag.
  5. maiconmassa
    23. Oktober 2014
    Any idea to solve this?
  6. N2k1
    N2k1 Well-Known Member
    8. Juni 2010
    Elephone P7000
    Elephone P8
    If you made a backup with MTK DT - did you convert the files for flash tool?
    The backup is not flashable itself - but the droid tool will correct this.
    There is also a valid uboot image (lk.bin)
    But if I remember right, there is only a setting in the build.prop to correct this.
    Try to search for "flipped display" (or similar)
    You may extract the old build.prop from your system.tar backup and put it to your phone.
    (Or read and compare line by line both build.prop files.)
  7. Ora
    Ora Tester
    22. Februar 2013
    Bluboo S1<- Frau
    Bezeichnung des Handys: GT-I9500 S4 1:1 MT6589 720 x 1280 Screen 512MB RAM+4GB
    Beschreibung: GT-I9190 Android 4.2.9 (customized Stock) basierend auf ALPS.JB2.MP.V1.26
    In unserer Download Datenbank FT Archiv
    I will renew the obsolete download link. Please be patience. :(
    The Rom will be only for this phone:
    At first try the following:
    -- search in your build.prop to this value "ro.sf.hwrotation=0"
    -- change to "ro.sf.hwrotation=180"
    or
    -- search in your build.prop to this value "ro.sf.hwrotation=180"
    -- change to "ro.sf.hwrotation=0"
  8. maiconmassa
    23. Oktober 2014
    Hi Ora, i tried this, but no success.
    I tried different roms and nothing happens ...
    'm desperate kkkkk
  9. Ora
    Ora Tester
    22. Februar 2013
    Bluboo S1<- Frau
    Please use the SP Flashtool and flash only the UBOOT Section with the LK File.
    Start a own backup from the whole phone first, please.
    mobile via T1
  10. maiconmassa
    23. Oktober 2014
    Yes, Well, I saw this on another forum, tried unsuccessfully more: //.
    I believe the problem is the lack of LCD driver. I also find it strange .. before giving problem I did the backup ROM by MTK Tools droid, the rom that is available for download at the beginning of the topic. The guy who sold the device not provided support, worse, his shop is no longer available: ///
