Goophone i5 N2 - Questions
Dieses Thema im Forum "General Discussions" wurde erstellt von munsterh, 12. März 2013.
  1. munsterh
    munsterh New Member
    14. August 2012
    Goophone Y5
    Thanks guys for this great threat and huge collection of tips for the Goophone i5 N2
    I just received mine yesterday from FCT. Reconfirmed with Antutu thats really the phone we are talking about in this threat (RAM: 1GB)
    Have listened to MayIandjay youtube instructions. Downloader m44tools and flashed the recovery image. Worked fine so far but I couldnt choose any of the options. I understand that you need to move the slider, but there was no slider on the initial screen. When I pressed the power button it showed a red box and the slider but the slider didnt move.
    OK - restarted. Flased again. Same thing
    Restarted again but this time flashed the recovery mentioned in this threat via the m44tool, not the flash tool. Restarted into recovery. CWM was there but guess what: I couldnt move up or down with the volume buttons. I just could press the restart option via power button.
    I then went into m44tool again and pressed temp cache erases. This was probably stupid as now the phone is constantly going into recovery, the android turns up for 2 seconds and then it goes into recovery moode again. I tried to press all combination of buttons and also the power button alone for indefinetely long. Doesnt change.
    I have not tried the flash tool since I dont know how to install the usb driver / adb thing.
    Any help of course would be appreciated. Also, I dont know where the reset button is...
  2. ColonelZap
    9. April 2008
    Xiaomi Mi4
    Next to the back camera.
  3. munsterh
    munsterh New Member
    14. August 2012
    Goophone Y5
    Between the Camera and the Flash? Using the SIM opener Tool? How Long do I Need To press?
    How do I use the Flash Tool? Wehre do I geht the USB drivers from?
  4. ColonelZap
    9. April 2008
    Xiaomi Mi4
    Yes
    It'll reset right away, no need to press it long.
    Check this out:
    http://chinamobiles.org/showthread....-Treiber-Installation-Test-CWM-Recovery-Flash
