Got 3G Network Connection with VodafoneES but still no Internet...?
Dieses Thema im Forum "General Discussions" wurde erstellt von ItsJoeMate, 15. August 2013.
  1. ItsJoeMate
    ItsJoeMate New Member
    15. August 2013
    Faea F1
    Hey Guys :)
    My Name is Joe and I currently live on Tenerife in Spain I also got the FAEA F1 now for about 2 Week and generally I'm pretty happy with it.
    -What I did in the beginning was putting a new Update on there and now my battery last about 3 days if I'm not using it too much with 2 Sim Card active. The Update I installed is linked in the bottom post of that page: http://forums.whirlpool.net.au/archive/2121634
    -The second thing I did was looking for a nice bag... The one I found is actually made for LT26I Xperia S and is from some Chinese Store. The phone fits Sizewise pretty well but I had to cut the hole for the camera bigger, make one for the speaker on the back and cut the power and volume button free... Like that it's quite good :)
    Let me know if you find a better solution for the mobil pocket... ;)
    Now there is only one Issue I still have. My provider here is VodafoneES. I got a good connection for 2G and 3G... meaning both Signal show very strong in the Top Bar. As well if I choose the Vodafone 3G network manually it connects properly...
    ...But now the Problem.: I'm not getting any working Data Connection, meaning my Internet is working only via WLAN but not if WLAN is switched off and DATA on...
    So I guess it must be something within the Software of the phone...?!
    Does anybody have the same Problem or any Suggestions, Updates of Fixes for that?
    Many thanks already now and I wish you all the best :)
    Cheers Joe
  2. Faea
    Faea Member
    2. Juli 2013
    Faea F1 verkauft
    Samsung S4, in Tonne
    Xiaomi Redmi 2 Pro, verkauft
    LeTV 1s x500, Premiumqualität!!!
  3. ItsJoeMate
    15. August 2013
    Faea F1
    Hey :)
    Thank you very much for your help! But the file you linked, didn't work to update my phone... It said Update aborted...
    But anyway I found a very simple solution...
    Downloaded Tweakker: https://play.google.com/store/apps/details?id=com.tweakker with my WiFi Connection in the Google Play Store and followed its instructions to set the APN manually and now it is working perfectly :)
    So all the best and thanks a lot!
    Cheers Joe
