GPS Problem
Dieses Thema im Forum "General Discussions" wurde erstellt von sumon530, 22. Februar 2013.
  1. sumon530
    sumon530 Member
    11. Februar 2013
    Can Any One Help Me For FIX GPS for my MT6577 Android Phone?
    My GPS Not Working
  2. Andycat
    Andycat Well-Known Member
    24. Juni 2008
    Redmi Note 2
    Yota phone 2
    Samsung S4 Zoom
    Es währe ja schön zu wissen was Du für ein Handy hast?
  3. sumon530
    sumon530 Member
    11. Februar 2013
    Star Galaxy Note 2 GT N-7102. I purchase it from FCT. GPs Not Working see attach file
  4. tommy0815
    tommy0815 Well-Known Member
    26. November 2010
    Samsung Galaxy Note 4
    Oppo Find 7
    Hey Sumon,
    i already showed you posting from N2K1. It will work 100% for you, please try it!!
    If you don't understand what to do, so ask, but it will work!
  5. sumon530
    sumon530 Member
    11. Februar 2013
    Yes I do not understand what to do.. please help step by step
  6. tommy0815
    26. November 2010
    Oppo Find 7
    ok i will try my best....i will edit this posting here soon.....but it isn't that easy because i can't do in real, so please be patient!
    Edit:
    here you can find the Post from N2K1 again:
    http://chinamobiles.org/showthread.php?33250-Firmware-fuer-HDC-GT-N7102&p=363679&viewfull=1#post363679
    I try to get it in short:
    please try:
    1. please delete the file "mtkpgs.dat" as N2K1 wrote you will find in "/data/misc/mtkpgs.dat"
    2. please activate A-GPS and EPO
    3. create outside a new file while using YGPS
  7. sumon530
    sumon530 Member
    11. Februar 2013
    cannot understand this line
  8. tommy0815
    26. November 2010
    Oppo Find 7
    you have to go outside with you phone and create a new file with the app "ypgs" (have a look in system and than app folder you will find there!)
  9. salinok
    salinok Member
    15. April 2011
    B92M
    "outside" means "do not do this step indoors ... do this in your garden, in a park or wherever"
  10. sumon530
    sumon530 Member
    11. Februar 2013
  11. tommy0815
    26. November 2010
    Oppo Find 7
    what exactly? To create a new file or?!?
  12. sumon530
    sumon530 Member
    11. Februar 2013
    at step 3 , just go to system/app/ and then click ygps .. it says install ygps.., click install ,then show install complete.. go to maps.. but after 30 sec say network location unavailable..
  13. tommy0815
    26. November 2010
    Oppo Find 7
    ok i can't help you in this point how this exactly work, because i won't create this (because my GPS is working), maybe you can ask "composer" how this step will be done correctly.
    Sorry, but can't help you this way.....
  14. N2k1
    N2k1 Well-Known Member
    8. Juni 2010
    Elephone P7000
    Elephone P8
    Oh, no!
    Do not click this file into a browser!
    You must enter engineer mode (you can do this with some dialer command (on my phone *#*#1478963#*#*) - or via the mobileUncle tools)
    Now you can run YGPS and wait until the fix.
    But there is an other musthave before: Your system time and time zone is necessary to set correct!
    (You can do this with the app fasterfix - and in Settings date&time to Network time.)
  15. sumon530
    sumon530 Member
    11. Februar 2013
    ok now i see six green circle and 4 red circle...in ygps chart... can it close now? or wait for all green circle..
  16. N2k1
    8. Juni 2010
    Elephone P7000
    Elephone P8
    Click on INFORMATION ans look te TTFF (time to first fix) and latitude/logitude - there should be a value (not running time in ttff field!)
  17. sumon530
    sumon530 Member
    11. Februar 2013
    yes TTFF show: 159898ms and lat: 23.8016...... and lon :90.36....... now can i close or wait?
  18. N2k1
    8. Juni 2010
    Elephone P7000
    Elephone P8
    You can Close all - you should have fix into other apps!
  19. sumon530
    sumon530 Member
    11. Februar 2013
    i back and go to my map.. but still see location not available...
  20. ColonelZap
    9. April 2008
    Xiaomi Mi4
