H2000 short battery life??
Dieses Thema im Forum "General Discussions" wurde erstellt von oldironman64, 11. März 2011.
  1. oldironman64
    oldironman64 New Member
    11. März 2011
    Nokia 5800, H2000
    Hi!
    I just received a H2000 and started to test. Some results:
    1. WIFI is really working well, touch screen is fine, processor seems to react fast
    enough. Android 2.2.1 is rich in features, you can find a 354 pages user's manual to
    download from the Internet.:eek: (The one shipped with the phone is a joke)
    2. Bluetooth can pair to another phone but can't connect (didn't try with handsfree yet)
    3. Some of the menues are still chinese although I ordered English (Ex. when trying to
    populate the home page with icons)
    4. Battery life time is 20 hours standby after fully charged (display off, phone lokcked)
    Phone statistics shows: 48% used by "phone idle", 48% by standby, 4% by WIFI.:!
    5. SIM in Nr.1 slot shows as SIM2 and Nr.2 shows as SIM1 on screen and messages.
    Rather upsetting when you try the right PIN on the wrong card 3-times.:crazy:
    I want to believe that my phone is one that jumped quality control and the type itself is a marketable phone.:negative:
  2. smoothie
    smoothie Active Member
    29. Dezember 2009
    iOCEAN x7
    ASUS Padfone 2
    iPAD2 WIFI 64 GB
    Sony xperia Z ( verscheknkt zum muttertag )
    Samsung Galaxy S3
    Hey, it must then be like that!
    also had one, just returned to the dealer
    had to reset firmware no longer function
    but until then I was very satisfied
    bluetooth works fine, with handsfree and other accessories
    Idle was great, over 60 hours in normal use
    fifth point yes the simslots are reversed
    I was not disturbed, was when my Pinphone so :)
    I think you need a better firmware for the phone, ask your vendor times
    or read-out like your current firmware is then I ask my vendor
    Greetings.
  3. oldironman64
    11. März 2011
    Nokia 5800, H2000
    Hi smoothie,
    Thanks a lot for the message. Now I know that I am not the only one.
    But I never got over 20 hours on either of the batteries in absolute standby.
    I also guesse that all these problems are coming from one of the programable modules. (Android or firmware)
    This phone is too busy when it is supposed to sleep. (Maybe it is snoring and using battery power)
    Here are some data about mine:
    Model: e1002_klx1
    Android 2.2.1
    Baseband: MAUI.10A.W10.48.MP.V0
    Kernel: 2.6.32.9
    BuildNr: ALPS.10Y.W10.48.MP.V1.06
    Do you have any idea if there is anything better, younger around?
    Best regards.
  4. schwayzee
    schwayzee New Member
    3. Januar 2013
    H2000+
    CPU*Sp*y output
    Android battery output
    Also struggeling with short battery life
    I could decrease the battery percentage of 15% within 3 minutes of HSDPA-browsing.
    Modellnummer
    H2000+
    Android-Version
    4.0.4
    Baseband-Version
    MAUI.11AMD.W12.22.SP..V7,2012/08/20 16:49
    Kernel-Version
    3.0.13
    test@test-virtualachine #1
    SMP PREEMPT Mon Nov 5 12:43:58 CST 2012
    Erstellungsnummer
    121115.ICS.V13.FWVGA.CN.COM.4P4.MT6628
