Hd2 t8585 dual sim usb connect problem with computer
Dieses Thema im Forum "General Discussions" wurde erstellt von klient78, 3. Februar 2011.
  1. klient78
    klient78 New Member
    31. Oktober 2010
    ja
    Hello
    My problem is so strange because i can't connect my phone with computer by usb cable this same time charging going properly .Is no action from both side when cable is plug in to the computer.I tried set connection directly from settings and also no change ,also does not help other cable,other computer,clean boot etc.
    I think pre-install rom but how I have do it and what from i have downland him ?
    Any idea what can be wrong ?
    thanks for any help
  2. daze
    daze Member
    24. Januar 2010
    Simvalley Rx-180 pico
    Tops A1 (android 2.2.1)
    What OS are you using on your computer XP or Win7? It's just a suggestion and I'm not sure if it's working but search in the registry for
    Hkey_Local_Machine\System\CurrentControlSet\Services\ USB
    and change
    "DisableSelectiveSuspend" from 0 to 1.
  3. kombo11
    kombo11 New Member
    7. Mai 2009
    Samsung f480
    you must change the battery
  4. klient78
    klient78 New Member
    31. Oktober 2010
    ja
    Hello
    thank you for your message i use xp and win 7 .
    I tried do it what did you suggest but without success,I think that problem is on phone side ...
    any one know where i can find right rom for this phone and how i have load new rom ?
    thanks for any ideas to resolve my problem !
  5. daze
    daze Member
    24. Januar 2010
    Where have u bought it? Maybe you write an email to the seller and ask him if he can send u the ROM. But the USB itself is working if u want to recharge the battery, isn't it?
  6. klient78
    klient78 New Member
    31. Oktober 2010
    ja
    Hi
    Problem is not resolve to this time I will send him back to factory for pre installing system I hope that help.
    thanks
  7. LowMan
    LowMan New Member
    8. November 2010
    Dual SIM T-Mobile HD2 Capacitive
    I had the same problem. Just disable KILT and everything will get back to normal :)
  8. klient78
    klient78 New Member
    31. Oktober 2010
    ja
    hello
    Thank you for you post ,my question is how i have do it ,I mean "disable KILT"
    thanks
