How to turn off "blue circle" function on Pinphone?
Dieses Thema im Forum "General Discussions" wurde erstellt von vvchin, 1. August 2010.
  1. vvchin
    vvchin New Member
    26. Juli 2010
    clone
    Hi there,
    I'm making a consideration to buy the Pinphone 3GS+ (dual SIM). Anyway, after reading posts, I found that the "blue circle" must be used to turn on speaker, mute, or even end the call.
    Is there a way to turn off the "blue circle" and simply touch the button directly?
    Thanks.
  2. Finchy
    Finchy Member
    12. August 2009
    Htc Desire
    No, there is no way to turn off the blue circle ...
  3. vvchin
    vvchin New Member
    26. Juli 2010
    clone
    hi Finchy, thanks a lot for quick reply.
    Cheers !
  4. Finchy
    Finchy Member
    12. August 2009
    Htc Desire
    Please ;)
    But this blue cricle is a good idea because you can't end the call with your face, if you talk with somebody ;)
