i95 Smartwatch Android 4.3 Call Reminder WiFi Heart Rate Monitor 512MB 4GB
Dieses Thema im Forum "Tinydeal.com" wurde erstellt von TinyDeal.com, 21. September 2015.
  1. TinyDeal.com
    TinyDeal.com Active Member Sponsoren
    17. Oktober 2014
    THL, Laude...
    Neue Smartwatch Empfehlung
    i95 Android 4.3 Call Reminder WiFi Heart Rate Monitor Bluetooth IP65 512MB 4GB Smart Watch f Android / IOS
      • Details:
      • Dial/answer phone calls
      • After connecting with smart phone, you can dial or answer phone calls.
      • WiFi Connection
      • i95 Smart Watch support WiFi, you can surf the Internet with high speed network.
      • 512MB RAM + 4GB ROM
      • Equipped with 512MB RAM and 4GB ROM, powered by Android 4.3, i95 Smart Watch runs more smooth; and you can save more data in it.
      • Bluetooth connection
      • Connect your phone to fulfill more functions.
      • 1.54 inch TFT HD LCD 320 x 320 touch screen
      • Best suitable screen size with high definition picture displaying gives you great experience.
      • Playing music and video
      • Play music and video saved in this watch; you can save more than 1000 songs in 4GB ROM.
      • Pedometer
      • You could count how many steps you have walked and this watch will count how long you have walked.
      • Heart Rate Monitor
      • The custom heart rate sensor in i95 Smart Watch can help gauge your intensity during workouts to improve overall calorie tracking.
      • Wake up by Gesture + Voice
      • You can operate though voice and your hand to wake up the screen, and simple operation time is under control.
      • Recording
      • High-definition WAV format recording noise reduction processing, high-definition distance recording.
      • Water Proof
      • i95 Smart Watch support IP65 water proof, it's more convenient for your daily life.
    i95 Heart Rate Monitor 512MB 4GB Smart Watch for Android / IOS E-468390 - TinyDeal
