i9B iPhone
Dieses Thema im Forum "Kaufberatung für Handys, Handyzubehör..." wurde erstellt von zeus1976, 12. Juni 2009.
  1. zeus1976
    zeus1976 New Member
    11. Juni 2009
    sony ericsson w580i
    help i need sombody :)
    also ich blick durch den ganzen clonewald nimmer durch
    hab mir das ausgesucht
    was haltet ihr davon ?
    laut beschreibung kann es auch java ! kann ich dann auch zusätzliche software installieren ?
    hat das teil jemand ? oder hatte es mal einer ?
    konnte hier leider nirgend´s infos finden
    danke im voraus gruß
    kalle
    http://www.cectunlocked.com/i9B-iPh...Phone-with-Bluetooth-Red-Elegant-Version.html
    Network:GSM 850/900/1800/1900 MHz (It does not have 3G functions)
    Quadband dual SIM standby phone
    3.2 inch, high definition flat touch screen
    Dimensions:113*61*13mm
    Available Language:English
    Display Type:QVGA, 16M colors
    Display Size:3.2 inch, high definition flat touch screen, 240×320 pixels
    Ringtones Type:polyphonic (72 channels),support mp3, mp4, midi of ringtone formats
    Ringtones Amount:grin:epend on the storage size
    Ringtones Customization:grin:ownloadable
    Vibration:Yes
    Music:Support MP3 background play, support equalizer, support bluetooth stereo
    Video:3GP/MP4, support to play in full screen, forward and pause, support video auto horizontal screen playing
    Phonebookt:Can store 500 phonebooks
    Connectivity:GPRS / WAP
    Internal Memory:4 GB internal memory
    Messaging:SMS, MMS
    Data transfer:USB cable/Bluetooth
    Games:Two common games, 3D games, QQ, support JAVA2.0 to set up on the memory
    Camera:Front & back high-definition cameras
    Support to shoot with sound, the time depends on storage size
    Stand-by time:100-350 hours
    Talk time:100-350 minutes
    Additional Features: Bluetooth, MP3/MP4, fluent player, FM radio, Calendar,Memo,Alarm clock, World time,
    Calculator, Voice recorder, WAP, MMS, GPRS download, Sliding unlock function, Voice
    control, E-book , JAVA 2.0, Support coming call turn over silent function, Support magic
    menu function, Stopwatch, QQ, E-map
    Package Contents:
    1 x i9B iPhone 3G Quad Band Dual SIM Card Standby Java Phone
    1 x Earphone
    1 x USB Cable
    1 x Charger
    1 x User Manual
  2. bendix92
    Online
    bendix92 Guest
    Ich habe es... und es ist schon nach nur 3 monaten kaputt. Der Knopf zum anschalten ist flöten gegangen. Ich würde es nicht empfehlen. Habe aber auch einen Testbericht geschrieben. Musst du mal nach suchen.
  3. zeus1976
    zeus1976 New Member
    11. Juni 2009
    sony ericsson w580i
    vielen dank für deine auskunft :)
    also ich habe die letzten tage nix anderes gemacht wie mich nach solchen handys umzuschauen :)
    dies
    http://www.cectunlocked.com/Newest-...one-MP3-4-Unlocked-Black-Elegant-Version.html
    ist nun in meine nähere auswahl gerückt
    ich brauche halt ein mit 2 aktiven sim´s
    aber ich will natürlich auch den ganzen tollen schnickschnack der möglich ist :)
    allerdings will ich auch keinen totalen schrott :)
    wlan wäre da noch toll :)
    bin aber vorsichtig weil die geräte die ich so gefunden habe im iphone stil ja mit der übersetzung da nicht so der brüller sind
    und wenn ich dann noch ein kabel bauen muß zum flashen oder so na ja ich weiß nit :)
    man findet ja auch nicht für jedes handy ne firmware
    für das i9 3g sollte es eine geben oder ?
  4. we3dm4n
    we3dm4n Helfer in der Not
    27. Oktober 2008
    Outkitel K6000PRO
    Dafür sollte es eine FW geben, ja.
    Es gibt nun seit geraumer Zeit schon Chinahandys mit 2 SIMs und WLAN. Guck da am besten mal bei Fastcardtech.com
    Ganz ehrlich würde ich dir aber von den i9x Modellen, genauso wie den i68x Modellen abraten. Die sind einfach im Großen und Ganzen minderer Qualität.
  5. SuperSpeMo
    SuperSpeMo Active Member
    25. September 2008
    P168+ Touch kaputt
    (nicht mehr)ZTC ZT5310
    Pinphone 3GS (verkauft :( )
    Zukünftig: HTC Desire Z
  6. zeus1976
    zeus1976 New Member
    11. Juni 2009
    sony ericsson w580i
    danke für den tip
    scheint sehr toll zu sein :)
    2gb is zwar ein bischen wenig aber man kann ja mehrere karten nutzen
    habe da keine info wegen den versandkosten gefunden ? (erledigt 34$)
    ist der shop gut ? hat da schonmal jemand schwierigkeiten gehabt ?
    habe nirgends info über das handy gefunden :(
    kann man evtl über firmwaremodding den speicher erhöhen ?
    2gb ist wirklich brutal wenig für son ding
    (habe gelesen das es karten bis 8gb unterstützt) kann das jemand bestätigen ?
    also wenn ja wird das ding anfang juli gekauft :)
    wo und was für software kann man dafür bekommen
    son pumpgun app wie beim iphone wäre brutal cool
    sowas in der art halt
  7. zeus1976
    zeus1976 New Member
    11. Juni 2009
    sony ericsson w580i
    kann keiner mehr helfen ?
  8. morenob
    morenob New Member
    9. Februar 2009
    MDA Touch Dual
    eigentlich keine Probleme, spreche aber nur von unserer Seite aus!
    spricht aber für Aufrüstung -bis zu 2GB wenn ich nicht irre. MfG. MoRe
  9. zeus1976
    zeus1976 New Member
    11. Juni 2009
    sony ericsson w580i
    so ich hab mit dem mal per msn geschrieben
    mein englisch is zwar grausam aber es hat dafür gereicht :)
    das teil unterstützt bis 8gb
    dhl is kein problem
    dieser andere versandverband kram da scheint ja schrott und zu teuer zu sein
    leider unterstützen die kein paypal
    mit moneybockers habe ich noch keine erfahrung :(
    kann mir da noch jemand was zu sagen ?
