Install jad(java)
Dieses Thema im Forum "General Discussions" wurde erstellt von jazmie, 6. August 2010.
  1. jazmie
    jazmie New Member
    22. Juli 2010
    pinphone
    i want install but error said memory not enough...need about 5MB memory...but i connect to pc and check my phone freespace still got 4GB.i tried install in memory and phone momory also failed...any idea?
    я хочу установить, но ошибка говорит памяти не хватает ... нужно около 5MB памяти ... но я подключить к компьютеру и проверить мой телефон FreeSpace еще есть 4GB.i пытались установить в память телефона и momory также не ... любые идеи?
  2. jazmie
    jazmie New Member
    22. Juli 2010
    pinphone
    in www.getjar.com
    phone type what suit with pinphone?...pinphone not in list
  3. we3dm4n
    we3dm4n Helfer in der Not
    27. Oktober 2008
    Outkitel K6000PRO
    To first question:
    "not enough memory" not means space it means RAM.
    Overall you can not install a .jad-file alone because this filetype only contains the link to the .jar-file (which is the real installation file for the program).
    Just normal^^
    Try the only CECT model in the list or sometimes a Nokia model like the 5800XM is very helpful...but really only sometimes...
