Internal storage and phone storage Star-Galaxy-Note-2-GT-N7102
Dieses Thema im Forum "General Discussions" wurde erstellt von sumon530, 25. Februar 2013.
  1. sumon530
    sumon530 Member
    11. Februar 2013
    Hello I have this this phone
    Star Galaxy Note 2 GT N7102 - $199.00
    In phone storage option I see this
    ( See Image 1)
    Internal storage 16GB
    But it not 16 GB
    when i go to Application option it see this ( see Image 2)
    Only 503 MB
    And Phone storage see 2 GB
    (see Image 3)
    I want to convert phone storage in to internal storage. how?
    or i want to create internal storage 2 GB instead of 503 Mb.. so i can setup more application in my phone..
    Can Any one Help me For this..
  2. sumon530
    sumon530 Member
    11. Februar 2013
    Any one here for help me?
  3. N2k1
    N2k1 Well-Known Member
    8. Juni 2010
    Elephone P7000
    Elephone P8
    Please open ADB shell and try this command: df -h post here the screen.
    Now try this command: mount and post the new screen.
    To change partition sizes, you can use the attached application.
    Doppelpost zusammengefügt nach 9 minutes:
    Read here: Zhou Xing i9300 - internal memory 500MB change to 2,5 GB
  4. sumon530
    sumon530 Member
    11. Februar 2013
    read here and i found
    Make backup of your data (as tar), install app, run app, choose 2,5GB, reboot into CWR and format data partition. Recover your data and reboot your system.
    Now you will have 2,5 GB internal data.
    Remember: Now you should change the vold.fstab to mount external SD card as first SD.
    how can i do this( read color write)
  5. N2k1
    8. Juni 2010
    Elephone P7000
    Elephone P8
    In the vold.fstab are 2 lines to Mount internal and external SD-Cards.
    Now Change the moutpint of external SD-Card to the mountpoint shown for the internal SD-Card and disable the other line (just by setting a # as first character in the line)
  6. sumon530
    sumon530 Member
    11. Februar 2013
    hello N2k1
    see attach file which line i edit or change..
  7. N2k1
    8. Juni 2010
    Elephone P7000
    Elephone P8
    Change in first line (without #) the sdcard into sdcard2
    and in the next line both sdcard2 into sdcard.
  8. sumon530
    sumon530 Member
    11. Februar 2013
    how can i make backup? can you tell the process?
  9. N2k1
    8. Juni 2010
    Elephone P7000
    Elephone P8
    You can use
    a) CWM or TWRP Recovery
    b) MTKDroidTools
    c) SP FlashTool
