Kingzone N3 Plus Full Review: An ugly MTK6732 5" phone
Dieses Thema im Forum "Smartphones" wurde erstellt von zijin_cheng, 23. März 2015.
  1. zijin_cheng
    zijin_cheng Active Member
    8. Februar 2015
    THL 5000
    Cubot X9
    Zuletzt von einem Moderator bearbeitet: 12. Januar 2018
  2. SnowyNight
    SnowyNight Well-Known Member
    17. Januar 2010
    weiblich
    Xiaomi Mi Note 3
    Thanks for the review,I don't believe it's ugly but for sure not the most attractive phone :3
  3. helldust
    helldust Active Member
    12. Mai 2013
    Xiaomi MI6
    Ugly? :hehehe: Man, not everyone likes materials like Aluminium which are tooooooooo soft and not durable for the real world. Take a look at the frame of an iPhone 4x. They don't look very beautiful after 1 year without bumper. Cheap crap sold as high-quality.
    Please stop this metall-is-perfect shit. Most of the new high-tech materials are made of carbon-fiber or plastic combined with it.
  4. zijin_cheng
    8. Februar 2015
    THL 5000
    Cubot X9
    Haha I tried to be as objective as possible but I just hated how it looked so much :)
    You definitely have a point there that not everyone is a fan of aluminum and that there are many phones that are made out of high quality carbon fiber/plastic that still feel very good, like the Ulefone Be Pro. However, the Kingzone's plastic does feel cheap when compared to other phones like the Ulefone Be Pro, their choice of glossy plastic doesn't make it feel premium. But as I said in my review, the plastic is light and very durable, bouncing like a ping pong ball.
  5. gsmfrank
    gsmfrank Well-Known Member
    25. April 2012
    LeEco Le S3 x626
    Elephone P8000
    Ups, muss man hier jetzt mit Translator arbeiten?:see_stars:
  6. wydan
    wydan Well-Known Member
    20. März 2013
    Blackview Crown
    C2 -1GB - MIUI
    sorry google translate
    Hello, thanks for the review
    A question about headphones sound, the sound can be heard better, as with other MTK , as the Yamaha audio chip king zone used
  7. thor2001
    Online
    thor2001 Well-Known Member
    11. Oktober 2013
    Honor 9 (STF-L09)
    Amazfit Cor/BIP
    @gsmfrank
    Er schreibt in Englisch ...und nein, er wird nicht das Forum übernehmen.
    He's writing in English ...and no, he won't overtake the board. :)
    Fragst du, ob der (Kopfhörer)Klang besser ist als bei gewöhnlichen MTK ist, da hier ein Yamaha-Sound-Chip verbaut wurde?
    Are you asking if the (headphone)sound is better than the regular MTK, because of the build-in Yamaha-sound-chip?
  8. wydan
    20. März 2013
    Blackview Crown
    C2 -1GB - MIUI
  9. thor2001
    Online
    11. Oktober 2013
    Honor 9 (STF-L09)
    Amazfit Cor/BIP
  10. digidu
    25. September 2014
    Mi 5
    fall about laughing ^^
  11. thor2001
    Online
    11. Oktober 2013
    Honor 9 (STF-L09)
    Amazfit Cor/BIP
    @zijin_cheng
    Regarding your written review:
    Thats correct, because the 64bit MTK-SoC are Multi-GNSS (GPS/Glonass/BeiDou), not Single-GNSS like pre MT6595-SoC.
    Interesting fact comparing N3 and N3+:
    N3 is NFC-capable, N3+ isn't
    A lot of people think, that the printed battery capacity is exaggerated (in many Kingzone-phones).
    You're not alone. :)
    A lot of chinese phones come with spy-/adware out-of-the-box, so I recommend a scan with a trustworthy AV-app.
    How dangerous the AV-hit really is, is another story and depends mainly on the needed app-permissions.
    First check on the AV-hit should be googling the app-name and/or the found virus-name.
    That should enable you to do a quick risk assessment and needed steps to resolve that matter.
    @wydan
    Hast du diese Stelle im geschriebenen Review gelesen?
    Have you read that part in the written review?
  12. StardustOne
    StardustOne Well-Known Member
    20. Februar 2013
    Samsung Galaxy Nexus
    Ich hatte mich auch für das Kingzone N3+ entschieden, es bestellt und dann später festgestellt, kein NFC mehr. Also habe ich die Bestellung storniert. Wieso aber die Shops alle mit N3 Bildern werben, wo man auf jedem Foto noch liest, da ist NFC drin, das ist ungefähr die selbe Schlamperei wie mit Sony Kamera beim Ulefone Be Pro werben nachdem bekannt wurde dass es gar keine Sony Kamera mehr drin hat.
    Nicht aufregen, einfach nicht kaufen :).
  13. gsmfrank
    25. April 2012
    LeEco Le S3 x626
    Elephone P8000
    @thor2001
    @wydan
    Das Thema hatten wir, glaube ich, schon mal.
    Nicht jeder kann englisch.
    Für englisch gibt es das hier: English Forum
    Wenn ich in einem englischen Forum deutsch schreibe geht das auch nicht.
    Snowden könnte doch dann in Zukunft auch in chinesisch schreiben.
    Gäbe es dann auch keinen Eklat mehr weil es sowieso keiner versteht.
    你應該寫德國在德國板中。
  14. mblaster4711
    mblaster4711 Well-Known Member
    30. Januar 2014
    THL5000
    was ist denn dass, sind da Hühner über den Bildschirm gerannt? :rofl
  15. wydan
    20. März 2013
    Blackview Crown
    C2 -1GB - MIUI
    thor2001
    danke dass hatte ich übersehen
  16. digidu
    25. September 2014
    Mi 5
    Hatten wir das Thema ala Sound aka MTK nicht schon letztens @wydan ?
  17. wydan
    20. März 2013
    Blackview Crown
    C2 -1GB - MIUI
    digidu
    kann sein, ich tu ja da schon eine zeit lang spekulieren und will auch mehr quellen haben.
  18. thor2001
    Online
    11. Oktober 2013
    Honor 9 (STF-L09)
    Amazfit Cor/BIP
    Ja, hatten wir schon einmal.
    Und ich sage dir auch jetzt wieder, nicht übertreiben.
    @zijin_cheng hat bisher DREI Reviews in Englisch gemacht.
    Wenn diese dir nicht passen, kannst du sie gerne getrost ignorieren. ;)
    Wird Chinesisch in der deutschen Schule gelehrt?
    Manche Forennutzer sollten etwas mehr Toleranz walten lassen und über deren Tellerrand blicken.
    Englisch ist nicht der Teufel, sondern Ignoranz und Sturheit.
  19. johndebur
    johndebur 迟到总比不到好。
    31. Oktober 2008
    Xiaomi Redmi Note 2 Prime
    Coolpad 9976A
    schön wärs, zumindest sinnvoller als Latein :)
  20. zijin_cheng
    8. Februar 2015
    THL 5000
    Cubot X9
    Yes the Kingzone has a Yamaha sound chip in it, and the headphone and speaker sound quality is better than the average MTK phone.
    So I guess I'll post my next reviews on the English portion of this website then, since some cannot read /understand English?
    I'm also testing a google translate friendly version of my english reviews, that way it can be easily translated to any other language.
    Just wondering how much English a person who's native language is German would they understand?
    My german ends at "Danke", "Ocktoberfest", "Martin Luther", and "Volkswagen". :)
