Leagoo Lead 1 - 5.5" HD OGS IPS, Wake Gesture, KitKat 4.4.2, Metallrahmen
  1. s7yler
    s7yler Youtube.com/s7yler
    26. Februar 2014
    OnePlus 5 / ZUK Z2 Pro / Xiaomi Mi5 / Elephone P9000 / Bluboo S8 / Doogee Mix / VKWorld Mix Plus / UMIDIGI Crystal / UMIDIGI Z1 Pro / Maze Alpha
    Leagoo Lead 1, OGS HD 5.5" Wake Gesture, KitKat 4.4.2, 5MM Metal Frame, MTK6582 1.3Ghz.
    Habe es von hier: http://www.dhgate.com/product/leagoo-lead1-5-5-quot-hd-ips-lcd-android/117320220.html man kann es auch bei efox hier bestellen http://www.efox-shop.com/leagoo-lea...ips-screen-android-442-3g-smartphone-g-293011
    UNBOXING
    MEGA REVIEW (26 Minuten + Pros & Cons)
    Kamera Samples:
    http://peecee.dk/uploads/072014/IMG_20140726_124204.jpg
    http://peecee.dk/uploads/072014/IMG_20140726_124101.jpg
    http://peecee.dk/uploads/072014/IMG_20140726_123717.jpg
    http://peecee.dk/uploads/072014/IMG_20140724_125738.jpg
    http://peecee.dk/uploads/072014/IMG_20140724_125420.jpg
    http://peecee.dk/uploads/072014/IMG_20140727_125037.jpg
    ROM (pre-rooted):
    http://www.needrom.com/mobile/leagoo-lead-1/
    Official ROM (30/8)
    http://www.needrom.com/download/leagoo-lead-1-2/
    ROOT Metode (drück "Spoiler" in die rechte Seite - ist in englisch)
    Thanks to de vetnek for the method! written by s7yler, this is how I rooted the Leagoo Lead 1. All normal tools will fail like vRoot, Shuame, Kingo, Towelroot, Framaroot
    0. Enabled "USB debugging" in "Developer options" on the phone
    1. Went to http://www.kingoapp.com, downloaded and installed the windows program "Bootloader unlock for Sony"
    2. Ran the program on the PC, connected the phone and pressed unlock. It then rebooted the phone to fastmode, then it hanged!
    3. Then I pulled the battery out (but I let the USB cable be connected still! and the "Bootloader unlock for Sony" program running still on the PC, I then inserted the battery again and hold volume up plus power down. Then I choose Fastboot and the bootloader program proceeded and ended finishing.
    4. After that I downloaded Kingo root tool, installed on PC, ran it, connected phone, let it run through the whole process, where it will reboot and check a lot of times. But it will then end with Roof failed! (after all tries is run).
    5. Then I installed Mobile Uncle Tools 2.9.9 (just the newest) and went to MTK engeering mode (MTK) and then swiped to the part called "log and debugging" tab an select "User2root", and the selected Root.
    6. Then I checked with Root checker, but it would say not rooted!
    7. Then I ran MTK droid tools, connected the phone! and MTK droid tools will show ROOT and green square!
    8. Then I went to tab 2 in MTK droid tools, and send the SuperSU into the phone, after that I could se a lot happening on the screen of the phone, so everything was installed. All went ok.
    9. Rebooted the phone
    10. After that I now had SuperSU, Mobile Uncle and Root explorer installed, now I again ran "Root Checker" and this time it would display ROOT in green!
    11. Done!
    Handy Spezifikationen: (Von Web kopiert!)
    5.5 inch IPS OGS Screen 1280 x 720 pixels
    MTK6582 Quad core CPU, 1.3GHz
    GPU: Mali-400 MP
    Cameras 5.0MP front camera, 13.0MP back camera with flashlight
    Operation System: Android 4.4.2
    Dual SIM Card Dual Standby
    RAM: 1G / ROM: 8GB
    Network: GSM900 GSM1800 WCDMA GSM1900 GSM850
    Wake Gestures
    CPU: Quad Core
    Feature: with Touch Screen with MP3 Video Player With Ebook with WiFi with GPS with Bluetooth with Email Dual Sim Card MMS
    Pros:
    Bildschirm ist ganz schwarz (mehr als z.B. bei Elephone P2000) wenn aus
    Es ist ein IPS OGS Bildschirm mit sehr guter Betrachtungswinkel
    Der Preis ist sehr gut
    3D Spiele laufen sehr gut! (z.B. Modern Combat 5)
    Doppel-Tippen auf dem Bildschirm zu wecken, oder zeichnen Sie z.B. ein C um direkt in die Kamera zu gehen.
    Autofokus in die Kamera ist sehr gut, man kann auch die Lautstärke-Tasten als Kamera Auslöser Taste benutzen.
    Die 3 Touch Buttons haben Rücklicht
    Material und Design ist sehr gut
    Das UI ist Flüssig und sieht gut aus (Leagoo UI).
    Hat Android Kitkat 4.4.2 (mit ein Leagoo skin)
    Wirelesss OTA updates funktioniert!
    Cons:
    Kein NFC oder OTG
    Kein Notifikations LED
    LED flash ist nur ein normalen weissen LED. (nicht so hell).
    (hat aber Beleuchtung in die Touch Buttons)
    Hat nicht so viele Sensoren, z.B. kein Kompass
    Der sound über Bluetooth war bei mir nicht so laut
    Handy wird bei 3D Spielen wie gewohnt ein wenig warm (35-45 grad laut BatteryBot)
    Leider nur ein MTK6582 mit 1GB ram und 8GB rom, aber für der Preis ist das OK!
    (Leistung ist aber immer noch sehr gut, und 3D Spiele laufen super)
    Nur der Metalrahmen ist 5 mm, Handy ist eher 8.2 mm dick in die mitte
    Zuletzt von einem Moderator bearbeitet: 12. Januar 2018 um 09:08 Uhr
  2. x990
    x990 Guest
    @s7yler wie ist den das GPS. Suche ein günstiges Navi und das Handy hört sich sehr gut an...
  3. s7yler
    26. Februar 2014
    GPS is durchschnittlich, im Auto hatte ich GPS lock in so 50-60 Sekunden. Aber ich glaube auch das es davon abhängt ob es bewölkt ist oder Bäume z.B. im Weg sind.
  4. x990
    x990 Guest
    OK danke... Das sollte ja ok sein...
  5. s7yler
    26. Februar 2014
    Hier ein Video die ich grade gemacht habe. Wo du den GPS lock sehen kann. Es geht recht schnell, stand aber draußen ein par Minuten, bevor der Aufnahme.
  6. x990
    x990 Guest
  7. x990
    x990 Guest
    Bekomm das Rooten nicht hin. Der Bootloader Unlock klappt nicht trotz Batterierausnahme.
  8. marko002300
    marko002300 Active Member
    18. Januar 2008
    div. in Familie
    5S Klon
    S4 Spark
    Leagoo Lead 1
    2x DG550
    vllt hilft es dir: ich habe in den letzten wochen meine beiden dg550 und ein htm gerät mit RootGenius_en gerootet. ich hatte mit herkömmlichen mitteln auch (warum auch immer) probleme.
  9. x990
    x990 Guest
    Leider hab ich jetzt ein ganz anderes Problem. Habe versucht die vorgebetet FW einzuspielen mit dem SP Flash Tool. Das Handy hat aber das flashen aber nie zugelassen. Jetzt geht das Handy gar nicht mehr an. Aber es wird erkannt. Wenn ich die FW einspielen will kommt aber immer eine Fehlermeldung. Wie komm ich da jetzt weiter?
    Es wirkt als ob es in irgendeinem Modus ist wo es nicht mehr rauskommt...
  10. s7yler
    26. Februar 2014
    Welcher Fehlermeldung ist das?
    Welcher SP Flash Tool version?
  11. x990
    x990 Guest
    Aktuell wird das Handy auch nicht mehr erkannt. Wenn ich es anstecke findet der PC ein USB Gerät das wars. Flachtool erkennt nichts. Hab die V5.13.53.200
    Ich hab nichts gemacht und jetzt ist es futsch oder wie?
    Es wird nur der MTK USB Port erkannt. :(
  12. s7yler
    26. Februar 2014
    Wird es bei MTK Droid Tools auf dem PC erkannt? kommt da info?
  13. x990
    x990 Guest
    Anscheinend nicht... Es wurde beim ersten Anschließen auch sehr warm, ist vielleicht was durchgebrannt? Ich mein wir reden von nem 80 EUR Handy...
  14. s7yler
    26. Februar 2014
  15. x990
    x990 Guest
    Ich bin ehrlich net so fit darin. Was genau heisst das...
  16. x990
    x990 Guest
    Laut Video brauch ich wohl ein Backup was ich aber nicht habe. Kannst Du mir eins schicken? Oder kann ich die Rom vom needrom nutzen? Die geht anscheinend aber nicht...
  17. x990
    x990 Guest
    Also ich lade jetzt die offizielle Rom von Leagoo weil bei der needrom Version kommt immer ein DRM Fehler beim flashen...
  18. x990
    x990 Guest
    An wenn kann ich mich wenden wenn es nicht klappt. Aktuell wird das Handy gar nicht mehr erkannt per USB. Da kann ich auch nichts versuchen zu flashen. Wer kann mir da helfen auch gegen Bezahlung.
  19. s7yler
    26. Februar 2014
  20. x990
    x990 Guest
    Brauch man einen vollen Akku damit das Handy noch erkannt werden kann. Der ist nämlich alle und glaube nicht das dieser lädt.
