Lenovo A750 usage experience and questions
Dieses Thema im Forum "General Discussions" wurde erstellt von LowMan, 5. Mai 2012.
  1. LowMan
    LowMan New Member
    8. November 2010
    Dual SIM T-Mobile HD2 Capacitive
    my old HD2, dual SIM clone is near it's end.
    So I need new dual SIM phone.
    Since it is clear that I will be not able to get Windows Mobile 6.5 phone (I got some apps that ONLY works on that system), I am looking for Android phone.
    Lenovo come to my mind, since I am hoping for little extra quality (my HD2 had problems with dust getting under the screen and after 3-4 cleanings, the screews where not that good anymore :().
    What I would like to know is:
    1. Is SIM 1 WCDMA/HSPA and default for internet connection (if not default is there know way to set it as default)?
    2. Have anyone tried connecting A750 to VW Premium bluetooth handsfree? There were some issues with my HD2 which I can live with (sometimes mic is not automaticaly turned on, so I have to do it manually), but I would like not to get to unusable handsfree.
    best regards
    LowMan
  2. Chocoball
    Chocoball 瞧好吧!
    28. März 2011
    Huawei P8 Max, OPPO R9S 新年特别版
    1. According to EtoTalk "It supports two 3G SIM cards for audio call in both slots. SIM 1 can use 3G data connection, but SIM 2 can not."
    2. Handsfree over BT will probably work however VW uses the rSAP protocol for using your phonebook . Some Android phones work and most won't only with the rSAP APK but that is only for ROOTed Samsung and HTC phones. There is also another APK for CyanogenMod 7.0 and 7.1 and AOSP based ROMs with version 2.3.x.
    Hope this helps.
