mobile i9+ with device bluetooth SCIPHONE I68
Dieses Thema im Forum "Allgemeine Informationen/Fragen" wurde erstellt von iphonei9+, 20. Januar 2009.
  1. iphonei9+
    iphonei9+ New Member
    19. Januar 2009
    i9+
    sorry but i write in english......
    1. this mobile no have nothing to print on box
    2. under battery i read i9+
    3. if i deal *#8375# i have answer px-xs2501-dt-m20-display Thai-set-20081017-00 ;branch:Gemini build:build_no, Serial #:250130019; build time : 2008/10/17 12.29
    4. my speakers are same in i68+ picture
    http://www.boykinsva.com/review/phone_review_003.htm
    5. in Main menu => Tools => Bluetooth => About in device i read SCIPHONE I68
    6. this mobile are touchscreen and touchflow on 3 page.
    7. if i dial *#06# i have imei:35395401xxxxxxx imei SV:78
    this my mobile inside...i bricked it in engineer mode..
    8.i'm idiot beacuse i dial this:.*#82043036* engineer mode
    i brick my phone too. in engineer mode with code ....*#82043036* after three seconds my phone has gone in shut-down......now my phone is dead.....and i need programm it again but i no have cable...
    http://img504.imageshack.us/img504/12pinblackcd2.jpg/1/w722.png[/IMG[/SIZE][/FONT]
    [FONT=Arial][SIZE=2][/SIZE][/FONT]
    [FONT=Arial][SIZE=2][URL]http://img504.imageshack.us/my.php?image=12pinblackcd2.jpg[/URL][/SIZE][/FONT]
    [FONT=Arial][/FONT]
    [FONT=Arial]this is my usb cable inside...i have pin 1,9,10,11[/FONT]
    [FONT=Arial][/FONT]
    [FONT=Arial][SIZE=2][URL=http://imageshack.us][IMG]http://img504.imageshack.us/img504/6821/picture006gr5.jpg
    http://img504.imageshack.us/my.php?image=picture006gr5.jpg
    i 've find this 3 cables for flash my mobile bricked...but i'm not sure which is better for me...
    http://www.ipmart.com/main/product/...n,COM,1,Cable,Compatible,27066.php?prod=27066
    http://www.mysciphoneshop.com/index...image&pID=16&zenid=g9v64rhiols04els2t7jrbc6n5
    http://cgi.ebay.com/USB-FLASH-CABLE...18?IMSfp=TL090118112003r30633#ShippingPayment
  2. saxghost
    saxghost New Member
    16. Juni 2008
    SE K750I
    i read this in the i9-Forum
    If your i9/i9+/i9-3G or any i9 model phone's USB cable has pins [1,9,10,11] active,
    then these are the same pinouts as the i68+ model phone and you will need an i68+ flash cable!
    and in mysciphoneshop i read this.
    *If your working usb cable is 1,9,10,11 then order "Flash download cable" for i68+. Add to Cart!
    I think that is the rigth one for you. If you need more information look at the i9forum.
    http://www.i9forum.co.uk (Menupoint -> Firmware)
    Greets saxghost
  3. karen
    karen Gesperrt
    28. April 2009
    nokia
    can not follow you!
    The unique picture i can not read crealy,
    But i know nichts da, keine Schleichwerbung! .
    Zuletzt von einem Moderator bearbeitet: 29. April 2009
