MSN Application
Dieses Thema im Forum "General Discussions" wurde erstellt von sammyano, 24. April 2010.
  1. sammyano
    sammyano New Member
    24. April 2010
    none
    Guys,
    there is mns.jar in java/app folder, however the MSN is not listed within the menu. How can I install MSN and make it appear under the home menu.
    thanks,
  2. Petteri
    Petteri Well-Known Member
    13. August 2009
    Tablets: Acer Switch 10
    Hi, it could help if you let users know what handy you have! :)
  3. ColonelZap
    9. April 2008
    Xiaomi Mi4
    You can't add any icons to the pinphone. If you flash the V1.1.3 firmware on the phone, it'll have a MSN icon :)
  4. sammyano
    sammyano New Member
    24. April 2010
    none
    thaks Conelzap, please do you have link for V1.1.3, my phone has the i835s_FN_CA_w_v1_1_2
    thanks
  5. ColonelZap
    9. April 2008
    Xiaomi Mi4
  6. sammyano
    sammyano New Member
    24. April 2010
    none
    Thanks Conelzap, please could point to the section 'How to flash' manual.
    thanks alot
  7. ColonelZap
    9. April 2008
    Xiaomi Mi4
  8. sammyano
    sammyano New Member
    24. April 2010
    none
    Cheers man,
    From Flash Tools > Options > Opreation methods - should it be set to 'NOR' OR 'NFB'
    Also, please advise of any required settings. Looking at the screen grap from the enclosed URL of how to flash there are four selected files where as my has only three.
    I do want to know what am doing b4 procedding. The FW V1.1.3 you sent me a link to, is this compatiable with my I835s which has FN_CA_W_V1_1_1_2.
    I have singed up for the flash cable sales on this site, as I have been having trouble to find where to buy one. I appreciate all your help, keep pointing me to the right direction or give any adive you can.
  9. we3dm4n
    we3dm4n Helfer in der Not
    27. Oktober 2008
    Outkitel K6000PRO
    - the FW 1.1.3 is compatible with your phone
    - under operation methods you need to select "NFB"
    - Just load the scat file of the given ROM and all needed files will be loaded into the list automatically
