MT6575 i9220 Rooting Problem
Dieses Thema im Forum "General Discussions" wurde erstellt von kputcha, 19. Oktober 2012.
  1. kputcha
    kputcha New Member
    19. Oktober 2012
    I have a SKY Galaxy Note I9220 LTE MTK6575 5.3 inch Screen Android 4.0 3G WCDMA Dual sim Dual standby 8MP WIFI GPS
    Android Version: 4.0.6
    Baseband Version: MAUI.11AMD.W11.50.SP.V17, 2012/05/05 15:38
    Kernel Version: 3.0.13
    When I try to root it...I get this: What is the solution ? Any help will be much appreciated...
    ____________________________________________________________________________
    Now we will attempt to root your device!
    failed on '/data/local/tmp' - Permission denied
    link failed File exists
    Rebooting (1/3) - Once your device has finished rebooting, then
    Press any key to continue . . .
    /system/bin/sh: cannot create /data/local.prop: Permission denied
    Rebooting (2/3) - Once your device has finished rebooting again, then
    uid=2000(shell) gid=2000(shell) groups=1003(graphics),1004(input),1007(log),1009(mount),1011(adb),1015(sdcard_rw),3001(net_bt_admin),3002(net_bt),3003(inet),3006(net_bw_stats)
    If the id is 0 / root then press any key to continue, otherwise press ctrl+c to cancel and start over
    Terminate batch job (Y/N)? y
  2. ColonelZap
    9. April 2008
    Xiaomi Mi4
  3. kputcha
    kputcha New Member
    19. Oktober 2012
    Yes, I have tried that...no luck...
    I can re-boot into Recovery, but cannot re-boot into Bootloader.
    I cannot mount /System in RW...even after changing it via Root Explorer from R-O to R/W, the permissions go back to R-O when re-booted.
    Any ideas on how I can gain RW control over /system ?
    How to unlock bootloader
