n7102 breaked need help please
Dieses Thema im Forum "General Discussions" wurde erstellt von dreampowerfx, 19. April 2013.
  1. dreampowerfx
    dreampowerfx New Member
    19. April 2013
    n7102
  2. tommy0815
    tommy0815 Well-Known Member
    26. November 2010
    Samsung Galaxy Note 4
    Oppo Find 7
    does computer recognize the phone?
  3. dreampowerfx
    19. April 2013
    n7102
    Only when i do V+ and pw
  4. tommy0815
    26. November 2010
    Oppo Find 7
    ok sounds good..
    can you tell me build nr of your phone?
    or can you show me a link to the phone in web?
    There are diffrent kinds of N7102!
    Do you have haipai one?
  5. dreampowerfx
    19. April 2013
    n7102
    http://www.*****************.com/n7...-mtk6577-dual-core-1gb-3g-wifi-gps_p5082.html
    Link http://www.*****************.com/n7102-android-41-phone-55-inch-ips-720p-screen-mtk6577-dual-core-1gb-3g-wifi-gps_p5082.html
    The link is http://www.*****************.com/ n7102-android-41-phone-55-inch-ips-720p-screen-mtk6577-dual-core-1gb-3. g-wifi-gps_p5082.html
    http://www. *****************.com/ n7102-android-41-phone-55-inch-ips-720p-screen-mtk6577-dual-core- 1gb-3g-wifi-gps_p5082.html
    The ******** is. whole saleon epiece
  6. dreampowerfx
    19. April 2013
    n7102
    And just join all parts of the names of the link in inside of the phone it only says GT-N7102
    Doppelpost zusammengefügt nach 4 minutes:
  7. tommy0815
    26. November 2010
    Oppo Find 7
    can't see even one link....may you sent me than again, by private mail?
    but please leave some spaces between... like w w w
  8. dreampowerfx
    19. April 2013
    n7102
    i just send an private mail
    Doppelpost zusammengefügt nach 23 minutes:
    w w w . w h o l e s a l e o n e p i e c e . c o m /n7102-android-41-phone-55-inch-ips-720p-screen-mtk6577-dual-core-1gb-3g-wifi-gps_p5082.html
  9. dreampowerfx
    19. April 2013
    n7102
  10. tommy0815
    26. November 2010
    Oppo Find 7
    sorry for that, but for this "really bad faked" phone i don't have firware!
    you get totally faked with this phone!
  11. dreampowerfx
    19. April 2013
    n7102
    now the phone torns on and have sound but not have image can you help me
  12. tommy0815
    26. November 2010
    Oppo Find 7
    can't help you, don't have image for this phone.....
  13. dreampowerfx
    19. April 2013
    n7102
    Hardware : SMDK4x12
    Model : GT-N7102
    Build number : JRO03C.N7100ZSALIA
    Build date UTC : 20121222-122033
    Android v : 4.1.1
    Kernel v : 3.0.31-178067 (se.infra@SEP-113) (gcc version 4.4.3 (GCC) ) #1 SMP Sat Dec 22 20:17:53 CST 2012
    Uboot build v : MAIN2.2.ubt.32381
    LCD Driver IC : 1-nt35516_6575_dsi
    Baseband v: MAUI.11AMD.W12.22.SP.V5, 2012/07/21 12:16
  14. Rumpelstilzchen
    21. Juli 2009
    Nexus 5
    Try to flash the phone with SPMultiPort Flashtool.
    There you can change the lcd driver (but only if your firmware supports different one)
  15. dreampowerfx
    19. April 2013
    n7102
  16. tommy0815
    26. November 2010
    Oppo Find 7
    @ Rumpelstilzchen
    is there a Tut available for MP Flashtool?
  17. Rumpelstilzchen
    21. Juli 2009
    Nexus 5
    I have never seen a tutorial.
    Here it is explained, but only in german: click
    It begins after the picture "download OK"
    The part after "EDIT: Hier mal schnell eine Anleitung um die Display Anzeige Fehler und Co. zu beseitigen:"
    There is also a download link for the flashtool.
  18. tommy0815
    26. November 2010
    Oppo Find 7
    But this is not MP Flashtool?
  19. Rumpelstilzchen
    21. Juli 2009
    Nexus 5
    just read below in the thread.
    As i explained. first it is a instruction for SP FlashTool.
    After that follows the instruction for Multiport (without pictures)
  20. tommy0815
    26. November 2010
    Oppo Find 7
    ah ok got it thx....but not really helpfull....if you will find a real tut will be very nice....because there are so many features, but don't know how to use them..
