i9 / i68 Neue FW I9+++ vom 17.03.2010 und wieder neue Codes
Dieses Thema im Forum "Allgemeine Informationen/Fragen" wurde erstellt von Sander, 4. April 2010.
  1. Sander
    Sander New Member
    23. September 2009
    Samkung IPAQ A128
    eFox H502 (i68+)
    I9+++ 2009er vers.
    i9+++ 2010er vers.
    Hallo, ich dachte ich lass euch mal teilhaben an meinen neuen Foruschen. :)
    Hab grad einen Readback meines I9+++ gemacht das die bis jetzt wohl neuste FW vom 17.03.2010 hat, und natürlich auch wieder neue Codes.
    Hier der DL Link zur FW(Danke COlonel): Klick
    CPU: MTK
    File size: 32 Mb
    ROM: X2501G_HW.2501G_0B_4455_ALL_V1_3R--100317.BIN
    BUILD: GEMINI 2501G_0B_4455_ALL_V1.3R X2501G_HW 2010/03/17 22:31
    [MCU SW] 2501G_0B_4455_ALL_V1.3R
    FS(fat) - Start: 0x1E00000, Size: 0x200000
    --- Languages --------------
    *#0044# |en-US| English
    *#0033# |fr-FR| Français
    *#0034# |es-ES| Español
    *#0048# |pl| polski
    *#0351# |pt-PT| Português
    *#0039# |it-IT| Italiano
    *#0049# |de-DE| Deutsch
    *#0060# |ms-MY| Bahasa Melayu
    *#0062# |id-ID| Bahasa Indonesia
    *#0420# |cs-CZ| Czech
    *#0031# |nl-NL| Dutch
    *#0084# |vi-VN| Ti?ng Vi?t
    *#0090# |tr-TR| Türkçe
    *#0007# |ru-RU| ??????? ????
    *#0966# |ar-SA| ???????
    *#0098# |ps-IR| Persian
    *#0066# |th-TH| ???
    *#0886# |zh-TW| ????
    *#0086# |zh-CN| ????
    --- LCD driver --------------
    lcd_main_ili9320_8bit.c
    lcd_main_ili9325_8bit.c
    lcd_main_ili9328_8bit.c
    lcd_main_un8999_8bit.c
    --- SpeedDial codes ---------
    *#0000# Auto language
    *#0044# Set English language
    *#0886#
    *#0034# Set Spanish language
    *#0048# Set Polish language
    *#0033# Set French language
    *#0049# Set German language
    *#0039# Set Italian language
    *#0066#
    *#0007# Set Russian language
    *#0351# Set Portuguese language
    *#0090#
    *#0084#
    *#0062#
    *#0420# Set Czech language
    *#0060#
    *#0031#
    *#0966#
    *#0098#
    *#0086#
    *#06# Show the IMEI
    *#9438375# Service
    *#9433646633# Service
    *#94366*# Service
    *#94387# Service
    *#94333778# Service
    *#943523# Service
    *#943678# Service
    *#943876# Service
    *#9436810# NICHT EINGEBEN - DANACH GEHEN KEINE CODES MEHR!!!
    *#1234# Set A2DP Mode
    *#900# BT Power ON
    *#901# BT Power OFF
    *#902#
    *#903#
    *#943251# Service
    *#943250# Service
    *#520520*# Service
    *#77773# Service
    *#77776# Service
    *#9433366*# Service
    *#422789# Service
  2. ColonelZap
    9. April 2008
    Xiaomi Mi4
    1. Bitte packen, die wird viel kleiner als 32MB
    2. Schau mal dort: http://fastfreefilehosting.com/
  3. Schussi
    28. Oktober 2007
    @ sander, mediafire wäre eine Möglichkeit.
  4. Sander
    Sander New Member
    23. September 2009
    Samkung IPAQ A128
    eFox H502 (i68+)
    I9+++ 2009er vers.
    i9+++ 2010er vers.
    Danke schussi, hab schon editiert.
    Der tip von Colonel war top. Danke.
  5. drhouse
    drhouse New Member
    13. März 2010
    Nokia
    hi, bin neu hier. was bringt mir die neue firm?
  6. joebac
    joebac New Member
    3. April 2010
    I9
    das wäre intressant zu wissen, spiele auch mit dem gedanken eine andere firm drauf zu machen
  7. Rumpelstilzchen
    21. Juli 2009
    Nexus 5
    Nur so zur Info,
    dazu braucht ihr ein spezielles Flashkabel.
    Mit dem normalen Datenkabel geht das nicht.
    Flashvorgang ist so, 2. Video für NOR-Flash: click
    Und die meisten Firmwares sind nicht kompatibel.
    D.h. die Chance das die neue auf eurem I9 läuft ist nahezu null :(
    Da ist eher das modden eurer eigenen angesagt. Macht aber auch Laune :)
    Grüße
  8. Sander
    Sander New Member
    23. September 2009
    Samkung IPAQ A128
    eFox H502 (i68+)
    I9+++ 2009er vers.
    i9+++ 2010er vers.
    Okok, ganz langsam.
    Ich hab die FW hochgeladen damit Ihr was zum Spielen habt. ;-)
    Bitte nicht gleich jeder Neuling diese FW draufhauen und dann maulen dass das Handy nicht mehr geht.
    WICHTIG!
    Erstmal braucht ihr, wie RUmpel sagt, ein Flashkabel. NICHT das Datenkabel.
    Dann unbedingt die eigene FW sichern, sprich Readback machen!
    Dann könnt ihr wenn ihr wollt die FW testen ob sie bei euch läuft.
    Wenn sie nicht läuft eure eigene wieder aufspielen.
    Zum Thema was es bringt:
    Normalerweise bedeutet neuere FW meist immer verbesserung, was aber bei China CLones nicht unbedingt sein muß. Deshalb nicht gleich drauflos Flashen sonder ERST im Forum INFORMIEREN was passieren kann und welche Risiken das Flashen hat!
  9. pablojose31
    pablojose31 New Member
    6. April 2010
    I9+++, K08 , W998(I-Phone)
    V802
    Und mal wieder ich mit ner bescheidenen Frage :)
    Welche Flashtool Version haste dazu benutzt?
    Meine schmeisst mir ständig ne Fehlermeldung ...
    MFG
  10. Sander
    Sander New Member
    23. September 2009
    Samkung IPAQ A128
    eFox H502 (i68+)
    I9+++ 2009er vers.
    i9+++ 2010er vers.
    Deine fehlermeldung sieht nach nem neueren NOR aus.
    Die bekomm ich auch bei meinem 2010er Model.
    Diese FW war auf einem 2009er Model dessen NOR wohl unterstützt wird.
    Zur eigentlichen Frage: Die aktuellste vers. aus dem DL bereich.
    Wird aber nicht gehen wenn du ein 2010er Handy Model hast, auch wenn da die FW wohl etwas älter ist scheint der NOR Typ neuer zu sein.
    So ganz hab ichs auch nicht kapiert aber ich muß auch noch auf eine neuere vers. warten um mein 2010er Model auslesen zu können.
  11. anidri
    anidri New Member
    19. April 2010
    Sci Phone
    ja aber wo kann man das runterladen ob gute oder schlechte übersetzung wo genau? ich habe ein i9+++
    Zuletzt von einem Moderator bearbeitet: 19. April 2010
  12. pablojose31
    6. April 2010
    V802
    @ Sander :
    Danke ... na dann warten wir mal ab :spiteful:
    MFG
