Nexoc pad 7 = egoman mid ?
Dieses Thema im Forum "General Discussions" wurde erstellt von An-DRUIDE, 16. Januar 2011.
  1. An-DRUIDE
    An-DRUIDE New Member
    15. Januar 2011
    NEXOC PAD 7 ( von EGOMAN hergestellt ?? ?)
    Anyone knows EGOMAN.COM.CN MID/ PAD/ TABLETS ?
    i am from Germany and have bought NEXOC PAD 7.
    it looks exactly like your MID 7-
    but NEXOC has no HDMI.
    NEXOC DATA SHEET:
    Display: 17,8 cm (7") 800x480 pixels WVGA TFT Display,
    Resistive Touch Screen
    Chipset: : Rockchip 2808 (= ARM926EJ-S rev
    2 Sensors: 1.EGOMAN 2-AXIS ACCELEOMETER V 1, 3.0 mA
    2. EGOMAN Orientation
    WiFI/WLAN: 802.11 b/g
    1x USB 2.0, 1x miniUSB 2.0, 1xHeadset/1x Mikrofon,--
    SD Memory Card up to 16 GB
    Battery: 4.000mAh Li-Polymer 5V
    AC Adapter: 100-240V AC ;
    - G-Sensor
    - Android Market, Internet Browser,
    - Videos:MKV, MPEG2, MPEG4, AVI, FLV, RM, RMVB, H.264
    - AUDIO: MP3, WMA, WAV, APE, FLAC, AAC, OGG
    - Video-Dekoder HD 720P
    - PHOTO/PICs: JPG, BMP, GIF, PNG
    - build in Loudspeaker
    - Built-In Flash Speicher 4GB
    - USB 2.0 High Speed
    The design is exactly like your MID 7 (HDMI etc)
    FIRMWARE Android, 1.5.1,KernelVersion: 2.6.25 rockchip version 1.2.7 (ruiguan)
    Buildnumber RK-1.3.3.eng.MID.20100917.125110
    It seems it has been build by EGOMAN.
    My Questions:
    Can you provide me with software and manuals
    how to get a ROOT status fpr my PAD?
    how to make a firmware flash or Custom ´flash? So i nedd FlashTool from you..
    Can you help me ?
    Thank you in advance
    regards
  2. mcinnocent
    mcinnocent Member
    24. Mai 2010
    Google G1,
    leeco-le1pro-x800-nur-us-version
    Samsung Galaxy S5 Duos
    Iphone 4S
    Lumia 630 Dual
    Is there meanwhile a new information about this subject, because i am also interested to know, if there is a possibility to upgrade the android-version in this pad?
  3. daybyter
    daybyter New Member
    26. März 2011
    Simvalley RX-80 Pico
    Hi!
    I was also trying to get some update going, so here is my current status:
    - I'm not aware of any downloadable firmware or update.
    - Superoneclick gives you adb shell root. So the current partitions can be dumped (already did this and uploaded them. Speak up if you need the link).
    - The backup partition is empty (so no firmware image from there).
    - The leaked RK 2808 packaging manager should/might work with the firmware components.
    - I'm not aware of any bootloader, that _definitely_ works with this pad. There _might_ be some, but I'm not sure which one works. Asked for help on this problem. Since I don't have any firmware image, I cannot extract the bootloader from there. I asked for help on this problem, but have to wait for a reply.
    - I should be possible to modifiy the system partition in the pad and add software etc.
    - Adding a new kernel is more problematic, since the bootloader might stop working then (a new kernel would be necessary to add new features like 3g support etc).
    - Distributing those modification is another problem, since it's not a simple update then.
    HTH,
    Andreas
