Ouki U1 - MT6589 5,7" HD 1GB Ram 4GB Rom 2500mah 2MP / 13Mp Cams JB dual sim
Dieses Thema im Forum "News von China Produkten" wurde erstellt von johndebur, 22. Juli 2013.
  1. johndebur
    johndebur 迟到总比不到好。
    31. Oktober 2008
    Xiaomi Redmi Note 2 Prime
    Coolpad 9976A
    MT6589 handy von ouki, soll 1099 yuans kosten ( 136€ )
    Hersteller: http://www.oukimobile.com/
    Produktinfo:
    http://www.oukimobile.com/en/product/view/id-71.html
    又见5.7英寸新机 欧奇U1低调上市开卖 mtksj
    Column 1
    [TR]
    [TD]Operating system
    [/TD]
    [TD="width: 386"] Android os 4.2.1 [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Number of cores [/TD]
    [TD="width: 386"] Quad [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] CPU model
    [/TD]
    [TD="width: 386"] MTK6589 [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] CPU frequency
    [/TD]
    [TD="width: 386"] 1.2Hz [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] RAM capacity [/TD]
    [TD="width: 386"] 1GB
    [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] ROM capacity [/TD]
    [TD="width: 386"] 4GB [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Memory Card Type [/TD]
    [TD="width: 386"] Microcd card [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Extended Capacity [/TD]
    [TD="width: 386"] 32GB [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Battery capacity [/TD]
    [TD="width: 386"] 2500MA [/TD]
    [/TR]
    Column 1
    [TR]
    [TD] Webcam [/TD]
    [TD="width: 386"] Internal [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Before the camera [/TD]
    [TD="width: 386"] 2,000,000 pixels [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Rear camera [/TD]
    [TD="width: 386"] 13 million pixels [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Sensor Type [/TD]
    [TD="width: 386"] CMOS [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Flash [/TD]
    [TD="width: 386"] LED lights [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Autofocus [/TD]
    [TD="width: 386"] Support [/TD]
    [/TR]
    Column 1
    [TR]
    [TD] Phone type [/TD]
    [TD="width: 386"] 3G mobile phones, smart phones, tablet phone [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Phone Size [/TD]
    [TD="width: 386"] 189 * 83.7 * 9.9mm [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] The main screen size [/TD]
    [TD="width: 386"] 5.7 inches [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Touchscreen [/TD]
    [TD="width: 386"] Capacitive screen, multi-touch [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Frequency resolution [/TD]
    [TD="width: 386"] 1280 * 720 pixels [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Network mode [/TD]
    [TD="width: 386"] GSM, WCDMA [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Data services [/TD]
    [TD="width: 386"] GPRS [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Support band [/TD]
    [TD="width: 386"] 2G: GSM 900/1800 [/TD]
    [/TR]
    [TR]
    [TD="width: 386"] 3G: WCDMA 2100 [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] Colors [/TD]
    [TD="width: 386"] White
    [/TD]
    [/TR]
    [TR]
    [TD="width: 101"] GPS navigation [/TD]
    [/TR]
    [TR]
    [TD="width: 386"] Gravity sensor type, light sensor type, distance sensor type [/TD]
    [/TR]
  2. JensK
    JensK Well-Known Member
    12. September 2012
    MI Note 2
    Die Bilder sind doch retuschiert, oder ? Auf der Rueckansicht sieht man die hervorstehende Kamera, auf den Seitenansichten links/rechts ist die Rueckseite vollstaendig eben und ohne jegliche Erhoehung.
    Ansonsten ein nettes Geraet, mit 2 GB RAM koennte ich drueber nachdenken.
