Pinphone 3GS battery question
Dieses Thema im Forum "General Discussions" wurde erstellt von waxxer, 20. Dezember 2009.
  1. waxxer
    waxxer New Member
    20. Dezember 2009
    hey!
    been following discussion about the pinphone 3gs for a while now (I can speek german pretty good, but writing is not my strong side and it goes a bit quicker in english).
    the forum is very helpful and has a lot of info, but I still have some concerns about the battery of the phone.
    - okay, what happens when for god knows what reason, the battery goes dead and you need a replacement?
    - if it still has warranty, you must send the phone back?
    - or will they send a replacement free of charge?
    - or can you buy one seperately and swap it out yourself? (been browsing through a lot of shops, but didnt find any.)
    I already asked fstcrdtch myself, but the anwser was "it has build in battery".........and thats really not helping me out.
    so, if any of you guys had a similar problem and/or know the answer, dont hold it back!
    cheerz!
    waxxer
  2. ColonelZap
    9. April 2008
    Xiaomi Mi4
    Actually it's not that difficult to replace the battery. It is "built in" but not soldered.
    All you need to do is to unscrew the two screws on the bottom of the phone, open the back and then the battery can easily be replaced.
    So, if FCT can get you one of those batteries, you should be able to replace yourself :)
  3. SuperSpeMo
    SuperSpeMo Active Member
    25. September 2008
    P168+ Touch kaputt
    (nicht mehr)ZTC ZT5310
    Pinphone 3GS (verkauft :( )
    Zukünftig: HTC Desire Z
    I will ask Philip of merimobiles when he is online,i think he can gave better infos than Fastcartech(just said something what was correct and they wont believe that).If he can order them i will give you a info.
  4. waxxer
    waxxer New Member
    20. Dezember 2009
    thanks for the quick reply guys!
    ColonelZap: doesnt sound too bad. :)
    SuperSpeMo: looking forward to it!
  5. waxxer
    waxxer New Member
    20. Dezember 2009
    okay, I may have an answer for my problem.
    fct is now selling one with two batteries and a silicone case for only five extra dollars.
    ..ach und Fröhliche Weihnachten!
