problem in updating pinphone
Dieses Thema im Forum "General Discussions" wurde erstellt von thejakal77, 18. September 2010.
  1. thejakal77
    thejakal77 New Member
    18. September 2010
    wewwrwr te e rysh hhdyddjdjjfj fj eskluty
  2. ColonelZap
    9. April 2008
    Xiaomi Mi4
  3. we3dm4n
    we3dm4n Helfer in der Not
    27. Oktober 2008
    Outkitel K6000PRO
    Overall I think the upgrade will not work because of compatibility problems...
  4. thejakal77
    18. September 2010
    i think i dont know how to uplode the picture i will try in another way
    any way is ther is any compatibility problem in these two softwares
  5. Rumpelstilzchen
    21. Juli 2009
    Nexus 5
    I can see your picture.
    I uploaded it again.
    Are you using a flashcable? You can not do that with the normal data-cable!
  6. thejakal77
    18. September 2010
    i am using the data cable
    what kind of cable i should use
    what kind of cable i should use???????
    Zuletzt von einem Moderator bearbeitet: 19. September 2010
  7. we3dm4n
    27. Oktober 2008
    Outkitel K6000PRO
  8. thejakal77
    18. September 2010
    thank u
    now i have to find this cable in syria
