[Q] - Iphone 4s 64Gb Clone
Dieses Thema im Forum "General Discussions" wurde erstellt von madalingtandaan, 8. November 2012.
  1. madalingtandaan
    madalingtandaan New Member
    5. November 2012
    iphone 4s clone
    i have an iphone 4s 64Gb clone which has a locked screen and i can't remove the passcode, i would like to reset the password or completely remove it.
    things i tried:
    1) i can turn off the phone and bypass the screen lock but i dont want to turn off the phone and on everytime i want to use it.
    2) the information on the phone is false (settings)(general) it says 5.1.1 on the information which means it iOS5 but i doubt it.
    3) get the battery off the phone if thats possible so it can reset. (just a guess)(just like bios)(i didnt think this worked i unsoldered the battery and left it for 8 hours and soldered it back)(passcode is still there)
    things i think i should do:
    1) get it to hard reset
    2) install a new ROM (but before that i have to determine what is installed so i need help on that too)
    any help would be appreciated. :)
    additional info on the general tab of the iphone:
    VERSION: 5.1.1(9B206)
    MODEL: MD234LL
    SERIAL: C39GTBXSD..
    The only thing that i know is i can reset (soft reset) (restore settings) is the code 1234
  2. ColonelZap
    9. April 2008
    Xiaomi Mi4
    Is that an Android phone? If so, try to boot into the recovery mode (maybe press and hold power and vol+), from there do a factory reset. Everything should be wiped, including the pass code.
  3. madalingtandaan
    5. November 2012
    iphone 4s clone
    thank you for your reply.
    i think it uses java OS and also i tried what you suggested and nothing happened the code is still there
