  2. Erfahrungen zu hier Werbenden Shops bitte in Ihre eigene Kategorie schreiben.
  3. Verbessert zusammen mit uns Chinamobiles.org und nennt uns eure Verbesserungsvorschläge für die nähere Zukunft in diesem Thread: KLICK
Efox-Shop repair shop Not honest
Dieses Thema im Forum "Erfahrungen NICHT werbender Shops" wurde erstellt von algaivoto, 9. November 2015.
  1. algaivoto
    algaivoto New Member
    9. November 2015
    THL 5000
    Sorry about the English.
    Bought a THL 5000 from Efox last November...all well until the on-off stopped working. I sent the phone in to repair last August. This "free" repair cost me 27 Euros to mail to China. ( no they don't have an European repair shop ) I just received the phone back from them after 3 MONTHS and the phone was not repaired. Because the warranty is about to run out I decided to open the back of the phone and found that the seal on one of the screws HAD NOT BEEN BROKEN and therefore the back of the phone had not been opened in the repair shop. THE CHINESE REPAIR SHOP HAD NOT OPENED THE BACK OF THE PHONE !
    Now I am told they will send me the part and I can try to have it repaired here in Austria...good luck....
    I had a similar problem with Banggood and they sent me a replacement phone. In the last three years I have not had a Chinese phone that has lasted the warranty period...It is getting too expensive to have a cheap phone...
  2. Herr Doctor Phone
    23. August 2009
    Cubot X9
    Samsung Tab GT-P7300
    sorry, my english is bad.
    der versand nach china geht auch billiger, und zwar als post sendung.
    das das schrauben siegel unangetastet ist, will nichts heißen, die kleben da ein neues drauf, zwar nicht immer, aber in der regel sollten sie.
    du hast das teil geöffnet sagst du? was hast du festgestellt?
    ist der powerknopf in ordnung? ist er gerissen oder kalte lötstelle?
    the shipping to China is also cheaper, as a mailpiece.
    the screw that's seal intact, nothing to say, the stick as a new plan, though not always, but usually they should.
    thou hast opened the part you are saying? what have you found?
    The power button is in order? okay? He is torn or cold solder joint?
  3. algaivoto
    9. November 2015
    THL 5000
    Ich öffnete die Rückseite des Telefons, und stocherte mit einem Schraubendreher. Es begann wieder zu arbeiten .... warum? Ich weiß es nicht :)
    danke für deine Nachricht
    (google translate)
  4. Herr Doctor Phone
    23. August 2009
    Cubot X9
    vielleicht war der power nicht richtig in seiner fassung, oder nicht richtig eingeclipst.
    viel spaß damit :)
    doc
