Resume Chinephonino, with update.zip generate from backup /dev/block/mtd[0-12] ?
Dieses Thema im Forum "General Discussions" wurde erstellt von salvarane, 18. August 2011.
  1. salvarane
    salvarane New Member
    18. August 2011
    Chine smartphon tipo HTC desire, Model A3QR android 2.2.1
    Dear friends,
    First of all I apologize if it is not the right place
    I have a smartphone made Chine, down slot battery I read this ID model : A3QR.
    Before making any changes, I performed all this steps :
    I Bkuped this partition
    dev: size erasesize name
    mtd0: 00020000 00020000 "preloader"
    mtd1: 00300000 00020000 "nvram"
    mtd2: 00020000 00020000 "seccnfg"
    mtd3: 00060000 00020000 "uboot"
    mtd4: 00400000 00020000 "boot"
    mtd5: 00400000 00020000 "recovery"
    mtd6: 00120000 00020000 "secstatic"
    mtd7: 00060000 00020000 "misc"
    mtd8: 0a000000 00020000 "system"
    mtd9: 03c00000 00020000 "cache"
    mtd10: 00300000 00020000 "logo"
    mtd11: 000a0000 00020000 "expdb"
    mtd12: 11340000 00020000 "userdata"
    with this commands
    dd if=/dev/block/mtd0 of=/mnt/sdcard/preloader.bin
    etc...
    How I can reconstruct the whole packet update.zip from these images of bkup ?
    From the site http://forum.china-iphone.ru, I followed some posts and I tested they, unfortunately does not work from the model phone A3QR :
    The smartphone have two slot for sim card, TV, radio, GPS and a sensor for movements.
    My proble is that I rewrited the partition /dev/block/mtd.. booting.img, in an attempt to load a kernel compiled by me.
    Now the phone when I turn it on, remains fixed on the classical image, the word Android reversed.
    Surfing in the forum, I found this package, Android_2.2.1_for_K8181.rar and I unzipped and take the file update.zip from the folder
    10HX5_WVGA_ANDROID2.2, after, I copied the archive update.zip to the root of the sdcard, I turned off the phone. I turned again the phone to on, pushing the power button + volume+ for 5 second, I entered in the menu, bootloader :
    I selected the option
    apply sdcard:updata.zip
    All ok the process is terminated with the words
    -- Install from sdcard..
    Installing update...
    Install from sdcard complete.
    When I reboot the phone, after that the process booting was loaded the word android, the screen had a white color and shaking, after some seconds the phone reboot alone, and again entered into the menu recovery.
    If someone from this forum, could help me to fix this problems, I would be grateful.
    Sincerely,
    Eugenio.
