Samsung S3 MTK6575 Issues !
Dieses Thema im Forum "General Discussions" wurde erstellt von fresco, 11. September 2013.
  1. fresco
    fresco New Member
    11. September 2013
    GTI9300
    Hello
    I have S3 Mtk6575 and there is some issues with gps?
    I tried many programs from store and still give me 0 Satellite!
    does anyone know which rom is the best to solve gps poor signal problem
    ty and sorry for my english.
  2. Daemonarch
    Daemonarch Chiclone-Lover
    20. Dezember 2011
    No.1-N3, Doogee DG2014, Samsung Galaxy S1+, S2, Note1, Note2...
    This is no rom issue, its an issue with poor antenna.
    You can try to do the following steps :
    - i don't know if this file does exist in --- ICS? what do you have - delete mtkgps.dat file with an root-explorer
    - activate epo & agps in gps-menu (download epo-files)
    - go outside and let the gps search (with gps-status)
    If the fix was found then once, the next time it should be found faster.
  3. fresco
    fresco New Member
    11. September 2013
    GTI9300
    Thanks Daemonarch for the comment
    I found the solution and it was easy, so between 30 seconds to 1 minute the signals will come easily.
    I will try to put the steps to how get the solution but enshalla later :)
  4. alexcool
    alexcool New Member
    18. November 2013
    zopo c2
    GPS of mtk platform is a nightmare.
    Sent from my Note 3 using Tapatalk
  5. JudyLan
    JudyLan New Member
    18. Juli 2014
    weiblich
    music
    Really?I have encountered the same problems for my phone.I thought maybe it is the signal problem,but seems not right,because other phones can work well in my place.so I will have a try.:yeees!:
