Sciphone 3G i68 compatible with original iphone accessories
Dieses Thema im Forum "Werbekategorie" wurde erstellt von karen, 28. April 2009.
  1. karen
    karen Gesperrt
    28. April 2009
    nokia
    This sicphone can use all iphone/iphone 3G accessories because it use the same connector. This is from the same manufactur of i68+. This sciphone also can use 3.5mm jack earphone. And, guess what, it's also quad band! This solve the problem of when the data cable or earphone broken it's hard to find your china seller and expensive to get replacement.
    The LCD screen is 3.2 inch. For a non smartphone, this is fairly big enough. This is the one of the best that we'd like to recommend among iphone clones. The back case cannot be removed, build in 1GB memory card. In the coming weeks, will have 2GB, 4GB, or 8GB as well. The back case will have apple logo in the coming weeks.
    Please note that even the applications is also try to be the same as iphone 3g. but actruall function is more or less like sciphone i68+
    Zuletzt von einem Moderator bearbeitet: 28. April 2009
  2. ColonelZap
    9. April 2008
    Xiaomi Mi4
    Please do NOT advertise here for your site and please remove your signature like I asked you in my PM!!!
  3. karen
    karen Gesperrt
    28. April 2009
    nokia
    ok,
    i will remove my signuture soon!
  4. Kareem85
    Kareem85 Ingeniör mit Auszeichnung
    10. Juni 2008
    Siemens SK65, Nokia 6820, ipple188, i68 , i68+, i9, i9+, Samsung D990, HTC Trophy
    not SOON you have to remove it NOW or i will CLEAR YOUR ACCOUNT NOW!
  5. karen
    karen Gesperrt
    28. April 2009
    nokia
    i try to remove it yestaday. but i can not do it successfull.
    Maybe i should hideaway it!
  6. Kareem85
    10. Juni 2008
    its already done by the administration. next time you should read the rules before you register to a forum!
    and if we see that you try to make business out here it will be the last time that you have been here on board!
