sd card memory VS phone memory(pinphone)
Dieses Thema im Forum "General Discussions" wurde erstellt von jazmie, 7. August 2010.
  1. jazmie
    jazmie New Member
    22. Juli 2010
    pinphone
    if phone connect to to usb,choose mass storage mode.
    -in pc explorer ist show the folder in sd card memory@phone memory?
    -how to check space avaible in phone memory and sd card memory?
  2. Rumpelstilzchen
    21. Juli 2009
    Nexus 5
    You are right.
    On your pc you can see two drives.
    One is the phone-memory, the other the sd-card.
    And how to check the space???
    Just look at the properties your pc is showing you ;)
  3. jazmie
    jazmie New Member
    22. Juli 2010
    pinphone
    how i just can c 1 drive(removable disk)?
    ist phone memory or sd card memory
  4. Rumpelstilzchen
    21. Juli 2009
    Nexus 5
    Edit:
    I checked that.
    On the pinphone you can always see only one drive.
    That is the whole memory of the phone.
    Including the sd-card :)
  5. jazmie
    jazmie New Member
    22. Juli 2010
    pinphone
    i check memory still 3GB..but install java game said error..need space 4MB...it should be enough...why happen like this?
    i try install in phone or sd card also same error.
  6. Rumpelstilzchen
    21. Juli 2009
    Nexus 5
    How many java apps have you already installed?
    It´s not possible to install as much as you want. The heap-size ist not too big on the pinphone.
    So deinstall another app and try it again.
    Hope that will help...
  7. jazmie
    jazmie New Member
    22. Juli 2010
    pinphone
    but my freespace still 3GB...still many...already try delete many java...got 2 only..but still same
  8. Rumpelstilzchen
    21. Juli 2009
    Nexus 5
    It´s a bigger java-app you want to install?
    I believe the pinphone is not able to run that app.
    The heap-size memory has nothing to do with the storage-memory.
    The heap-size is a part of the RAM that is for running java-apps. That one will be to small...
    Can you try to install a smaller app? That should work instead.
  9. jazmie
    jazmie New Member
    22. Juli 2010
    pinphone
    oic...heap memory=RAM
    that java just need 4MB only
    other java application can
    one more..i run video...then i close application by push home button on phone...i try running again that video error said insufficient memory...then i try restart the phone then the video i can run...y this happen?
    ist i push home button to close the video,the video still running in background?
  10. Rumpelstilzchen
    21. Juli 2009
    Nexus 5
    If another java app is running than the pinphone can´t work with the "bigger" one.
    And video:
    i don´t think it is running in the background.
    But you should ever close the media-player correctly.
    Than that problem will never appear again :)
  11. jazmie
    jazmie New Member
    22. Juli 2010
    pinphone
    RAM for pinphone how many?
