[SOLVED] Problem Install CWM GT-N7102
Dieses Thema im Forum "General Discussions" wurde erstellt von leonard9500, 14. Juni 2013.
  1. leonard9500
    leonard9500 New Member
    9. Juni 2013
    HDC Galaxy S4
    Hi community! I'm having troubles to install the CWM on my N7102. I've already had troubles to root the device, I tried with a lot of tools like SuperOneClic, MTK Root All, MTK Droid Tools, and with different scripts, but finally I could root it with a chinesse tool called ZhuoDaShi.
    Now I'm trying to install the CWM but I'm not succeeding. I tried to flash the recovery.img that @tommy0815 put in the post http://chinamobiles.org/showthread.php?34423-I-need-CWM-For-GT-N7102-MTK6577 , but I'm having troubles with the SP Flash Tool. I tried to flash it with three different versions of the SP Tool, v2.1140.0, v3.1304.0.119, v3.1224.01 but I was getting the error 8038 with all that versions.
    I also tried with the Odin tool, but It doesn't detect the phone. I tried with some scripts too, like flashrecovery, cwm5ics.
    I really don't know what I'm doing wrong. Any ideas?. Thank you in advance.
    P/D: This is my device:
  2. Ora
    Ora Tester
    22. Februar 2013
    Leagoo Elite 1 <- Frau
    Vernee Apollo <- soll ELE Vowney mal ablösen
    Hi leonard: It is a well known bug.
    Please do the followings:
    Edit your scatterfile.
    Replace only the the strings "__NODL_FAT" with "FAT".
    After this all things work fine now.
  3. leonard9500
    9. Juni 2013
    HDC Galaxy S4
    Thank you for your reply @OraChinaMobiles!, I've made the change in the scatterfile but I'm getting the same error as always:
  4. Ora
    Ora Tester
    22. Februar 2013
    Please download your original scatter.txt here.
  5. leonard9500
    9. Juni 2013
    HDC Galaxy S4
    This is the scatterfile that I used in the thread: http://chinamobiles.org/showthread.php?34423-I-need-CWM-For-GT-N7102-MTK6577
    This is the Den Anhang MT6577_Android_scatter_emmc.txt betrachten (I've modified the value "__NODL_FAT" to "FAT"):
    PRELOADER 0x0
    DSP_BL 0x40000
    MBR 0x600000
    EBR1 0x604000
    __NODL_PMT 0x608000
    __NODL_NVRAM 0xa08000
    __NODL_SECCFG 0xf08000
    UBOOT 0xf28000
    BOOTIMG 0xf88000
    RECOVERY 0x1588000
    SEC_RO 0x1b88000
    __NODL_MISC 0x2188000
    LOGO 0x21e8000
    __NODL_EXPDB 0x24e8000
    ANDROID 0x26e8000
    CACHE 0x227e8000
    USRDATA 0x428e8000
    FAT 0x810e8000
    __NODL_BMTPOOL 0xFFFF00a8
  6. tommy0815
    tommy0815 Well-Known Member
    26. November 2010
    Samsung Galaxy Note 4
    Oppo Find 7
    please create new scatter with droid tools from your device.......where did you get this scatter or is it already from droid tools?
  7. Ora
    Ora Tester
    22. Februar 2013
    AW: Problem Install CWM GT-N7102
    Please read back your own scatter file from smart phone at first and compare with the file from thread.
  8. leonard9500
    9. Juni 2013
    HDC Galaxy S4
    Here are the two scatters:
    1. This is from the thread: http://chinamobiles.org/showthread.php?34423-I-need-CWM-For-GT-N7102-MTK6577
    PRELOADER 0x0
    DSP_BL 0x40000
    MBR 0x600000
    EBR1 0x604000
    __NODL_PMT 0x608000
    UBOOT 0xf28000
    BOOTIMG 0xf88000
    RECOVERY 0x1588000
    SEC_RO 0x1b88000
    LOGO 0x21e8000
    ANDROID 0x26e8000
    CACHE 0x227e8000
    USRDATA 0x428e8000
    __NODL_FAT 0x810e8000
    2. This is the one created by the droid tool:
    UBOOT 0xF28000
    BOOTIMG 0xF88000
    RECOVERY 0x1588000
    SEC_RO 0x1B88000
    LOGO 0x21E8000
    __NODL_EXPDB 0x24E8000
    ANDROID 0x26E8000
    CACHE 0x247E8000
    USRDATA 0x468E8000
    FAT 0x689E8000
    __NODL_BMTPOOL 0xFEAFFFFF
    As you can see the only difference between them is the line "__NODL_FAT", but I've used both scatterfile and I'm getting the same error 8038.
    This thing is really really driving me crazy!!, I want to throw this device through the window!!!.
  9. leonard9500
    9. Juni 2013
    HDC Galaxy S4
