sophone help about language, music and internet. (English)
Dieses Thema im Forum "General Discussions" wurde erstellt von sophonizer, 19. März 2011.
  1. sophonizer
    sophonizer New Member
    19. März 2011
    sophone
    hallo,
    I have been trying to understand some german threads, but it is very difficult... So I apologize if the topic has been discussed before, I couldn't find any english version.
    I bought a sophone and would like some basic help about the things mentioned above:
    I downloaded opera mini but i dunno where to put it to make it work.
    1-The keyboard is only in chinese or english with normal letters, but I would love to have å ø æ as well, even ö ä would make it better.
    2-I can't manage to make my mac read the sophone when connected, is there a trick or something?
    3- Last but not least, I downloaded some music from my job-PC but I don't know how to put the covers on, so they will show in the ipod application.
    that was a loads of question, I hope some of you can answer,
    Thank you very much in advance!
  2. ColonelZap
    9. April 2008
    Xiaomi Mi4
    1. That won't work.
    2. Probably only via Bluetooth, Macs don't like MTK-Phones.
    3. You need to put a "music.jpg" picture into each of your album folders.
  3. sophonizer
    19. März 2011
    sophone
    thank you so much! that worked actually!
    do you know how I can fix internet/browser? I downloaded opera mini but when I unzipped it I got many files, have no idea what to do with them.
  4. ColonelZap
    9. April 2008
    Xiaomi Mi4
    You should't upack it, it should be just ONE *.jar file.
  5. sophonizer
    19. März 2011
    sophone
    ok,
    I managed to connect through bluetooth, I sent both bolt.jar and opera.jar files to the phone.
    they are in the "received files" folder, when I click on one of them it says error...
    Sorry for bothering like this, I wish I could sort this out by myself...
  6. ColonelZap
    9. April 2008
    Xiaomi Mi4
    I don't know :( Maybe you should move them somewhere else on your SD card and then try to install them from there?
  7. Petteri
    Petteri Well-Known Member
    13. August 2009
    Tablets: Acer Switch 10
    There is a trick....if you push the .jar file there comes "error"...thats right.....BUT you must NOW push on the Options Button on Header Left! so it starts.....tricky but works....
  8. sophonizer
    19. März 2011
    sophone
    I managed to install it :)
    I'll tell you how I did, in case someone else has the same trouble.
    In the "received files" folder I created a new folder named "browser" then I could click on the .jar file and right after on the options button on the header, and it suddenly worked!
    Now I got one more problem... the covers on my ipod list are gone, I can see the files in the folders, but there's no cover on the ipod app. I can play all the songs though. I really hope to get this phone to work at 100%, it seems solid and has a nice flow, but some instructions would be nice to have...
  9. ColonelZap
    9. April 2008
    Xiaomi Mi4
    Maybe you need to refresh the list?
  10. sophonizer
    19. März 2011
    sophone
    I already tried that :)
    There must be something tricky here, yet simple...
    Today I fooled a friend, he tought it was the real iphone4 ;)
  11. ColonelZap
    9. April 2008
    Xiaomi Mi4
    Did your phone come with some music already on it? Westlife for example? If so, take a look what format the music.jpg has and try to make your own pictures similar to the pixel and kb size.
  12. sophonizer
    19. März 2011
    sophone
    That is actually a good idea, but the problem is that I deleted all the music... Do you have a sophone yourself? if so maybe you could tell me?
  13. Loonix
    Loonix Spokenkieker
    4. Juli 2009
    Jiayu S3 Advanced
    hmm, on the i68+ and so on the name was 'folder.jpg' if i recall right
    and it had to be quite small (80x80 or something like that)
  14. ColonelZap
    9. April 2008
    Xiaomi Mi4
  15. sophonizer
    19. März 2011
    sophone
    I will give it a try and I will write here what happened ;)
  16. sophonizer
    19. März 2011
    sophone
    ok, I tried to do like ths:
    with the file music.jpg you sent me I can see the cover in the cover flow, but with the files I put there I couldnt. Now I wonder what's special about this file, it must be 300x300 and maybe must be 30kb. I will try again with some other files and let you know.
  17. ColonelZap
    9. April 2008
    Xiaomi Mi4
    I really can't tell you what the problem is? So far I could use pretty much ANY picture, I didn't even worry about the correct format.
    Good luck :)
  18. sophonizer
    19. März 2011
    sophone
    ok, I found out how :)
    there's no problem using big pictures, but you have to rename them "music" and put them in the right folder. For example if in my music list I have a folder named "Michael Jackson -Thriller" I just put the cover in that folder and then I rename it "music", then it works.
    I found out when I saw your file, so thank you!! :)
  19. ColonelZap
    9. April 2008
    Xiaomi Mi4
    You're welcome :)
    Maybe I didn't make myself clear enough when I wrote
  20. sophonizer
    19. März 2011
    sophone
    AHH, that's what you meant.... well I finally got it :grin: now the coverflow looks like a real IPHONE, wonderful!
