Star ulefone U9592 - 5" HD MT6592 2GB Ram 16GB Rom 2/8MP Cams
Dieses Thema im Forum "Shanzhai News" wurde erstellt von johndebur, 20. Januar 2014.
  1. johndebur
    johndebur 迟到总比不到好。
    31. Oktober 2008
    Xiaomi Redmi Note 2 Prime
    Coolpad 9976A
    MT6592 Handy von Star:
    http://www.ule-star.com/?Product/20.html
    ■ MT6592-1.7GHz 28 nanometer quad-core speed (low-power Cortex-A7 architecture)
    ■ 5.0 英寸 HD 1280x720 IPS screen
    ■ Memory RAM: 2G + ROM: 16G
    ■ Front 2,000,000 + 8,000,000 after AF selectable (with flash)
    ■ 3G (WCDMA / GSM)
    ■ 9.4 毫米 thin body ■ 2800 mAh Li-ion battery ■ Smart Cover comes equipped with Android 4.2.2 system ■ ■ Support for 3G, Wi-Fi CERTIFIED Miracast, EDGE, HSPA +, HSUPA
    ■ Wi-Fi CERTIFIED Miracast, EDGE, HSPA +, HSUPA
    Detailed explanations.
    • Style: PDA touch Size: 140x71.8x9.4mm
    • Product weight: 163 g Hardware platform: MT6592 - 1.7GHz 28 nanometer quad-core speed (low-power Cortex-A7 architecture)
    • Internal (memory): RAM: 2G + ROM: 16G
    • System: Android 4.2.2 OS
    • Mobile phone standard: WCDMA / GSM
    • Support band: WCDMA 2100/850 (HSPA +) and GSM 850/900/1800/1900
    • SIM card: Dual card dual standby Navigation: Built-in GPS chip (GPS + AGPS)
    • Display: 5.0 inches HD IPS screen 16 million color main screen resolution: 1280x720 pixels
    • Camera: After the former 2,000,000 + 8,000,000 AF selectable (with flash)
    • Wireless transmission: 3G, Wi-Fi CERTIFIED Miracast, Bluetooth 4.0, EDGE, HSPA +, HSUPA
    • Modem features: Mobile AP - wireless AP (WLAN hotspot)
    • HSUPA (High Speed Uplink): Supports up to 5.76 Mbps;
    • HSPA + (High Speed Downlink): Supports up to 42 Mbps;
    • Light sensor: Support Proximity sensor: Support Gravity Sensor: Support
    • FM function: Support
    • Java extensions: Support music / video taped: Support
    • WAP browser: Support handwriting input: Support for multiple languages Support the expansion card: TF Card (up to 32GB)
    • Battery parameters: Standard Battery capacity: 2800mAh
    • Talk time: 120-150 (Unit: minutes)
    • Standby time: 120-180 (Unit: Hour)
    • Phonebook capacity: 10000 Group SMS / MMS: Support headphone jack: 3.5MM standard interface
    • Charging Interface: mini usb 5pin Interface
    • Color: Ivory, sapphire blue
    • Included: Smart Cover
    Banner.jpg T2.K3wXXlaXXXXXXXX_!!27189466.jpg T2HUZvXdVaXXXXXXXX_!!27189466.jpg T2Qw.xXXlXXXXXXXXX_!!27189466.jpg T2SagxXhXXXXXXXXXX_!!27189466.jpg T29LowXelaXXXXXXXX_!!27189466.jpg
  2. Nomex
    Nomex Member
    28. Mai 2010
    HDC Ultimate Thin
    wer schnell ist kanns ja noch bei cect bestellen. wäre gespannt wie da der akku ist. und wie immer die preisfragen, was vom original passt
  3. YanChung
    YanChung Ich mag Urlaub ❤
    31. Dezember 2013
    weiblich
    No.1 S6
    Ist es gleich wie Ulefone U650?? Was ist der Unterschied??
  4. SnowyNight
    SnowyNight Well-Known Member
    17. Januar 2010
    weiblich
    LeEco Le Max 2
    naja das 650 hat ein 6,5" display :) schon ein kleiner aber feiner unterschied ^^
  5. Rosenklotz
    Rosenklotz Active Member
    22. August 2012
    Redmi Note 4x
    Flasht mich irgendwie nicht. Okay, Octacore, schön und gut, aber der ganze Rest? 9,4mm dick, 5" 720p, 2/16 GB... nee, irgendwie unattraktiv für mich.
  6. YanChung
    31. Dezember 2013
    weiblich
    No.1 S6
    hmm..danke schön.;)
  7. SnowyNight
    17. Januar 2010
    weiblich
    LeEco Le Max 2
    die 720p bei 5" ist das einzige was ich wirklich mag..
    weil das sicher auch akkuschonend ist...
    mein note 2 hatte auch 720p mit 5,5" habe da nie pixel gefunden o.o aber naja ^^ geschmackssache
  8. Rosenklotz
    22. August 2012
    Redmi Note 4x
    Ich finde die Auflösung und Displaygröße auch völlig OK, aber die braucht keinen Octa, da tut es auch der 6582. Und dann bleibt ja die Frage, welchen Vorteil das Phone mir bietet?
  9. Daemonarch
    Daemonarch Chiclone-Lover
    20. Dezember 2011
    No.1-N3, Doogee DG2014, Samsung Galaxy S1+, S2, Note1, Note2...
    Einen 1:1 N3-clone mit den Daten fände ich äußerst interessant!
  10. Smuji
    Smuji Active Member
    1. September 2013
    Omnia 7
    Das ist aber nicht wahr. Das teil hat nur eine aufloesung von 854 x 480 pixels
    Habe es mir bei mixeshop bestellt, dann haben sie mich heute angeschrieben und mir gesagt dass es ihnen leid tut, dass sie sich vertan haben und das handy doch nur 854x480 pixel hat.
    Ich verstehe die welt nicht mehr. Ab und zu findet man das handy im internet mit angeblich hd aufloesung und 2800 mah akku und manchmal nur 854x480 und 2300 mah....
    Gibt es verschiedene versionen oder was
