SUNNO Q880 Rom update
Dieses Thema im Forum "General Discussions" wurde erstellt von api29, 11. Juli 2010.
  1. api29
    api29 New Member
    11. Juli 2010
    Sunno Q880
    Hy all!HELP!!!Sunno Q880 rom update???Sorry but not speak english.
  2. Petteri
    Petteri Well-Known Member
    13. August 2009
    Tablets: Acer Switch 10
    What do you want?! A ROM or help how to flex the Sunno?!
  3. api29
    api29 New Member
    11. Juli 2010
    Sunno Q880
    [Quote = Petteri , 236 965 ] Mit akarsz ? A ROM-ot , vagy segít , hogyan lehet rugalmas a Sunno ? [ / quote ]
    I want ROM (6.5) and updater program+usb driver.
    The hardreset not help!!!
  4. Petteri
    13. August 2009
  5. api29
    api29 New Member
    11. Juli 2010
    Sunno Q880
  6. ColonelZap
    9. April 2008
    Xiaomi Mi4
  7. api29
    api29 New Member
    11. Juli 2010
    Sunno Q880
    Very thanks the link!!!
    PROBE
  8. api29
    api29 New Member
    11. Juli 2010
    Sunno Q880
    The IDT passwors is inkorrekt!!!
  9. ColonelZap
    9. April 2008
    Xiaomi Mi4
  10. api29
    api29 New Member
    11. Juli 2010
    Sunno Q880
    Ok Thank!!!The program is running!!!
    The program is running,but not good the img file,in rar pack
    Q880_Sunno_11-??.bin <---this format is a problem!!!(??)
    Rename?
    not running
    Zuletzt von einem Moderator bearbeitet: 11. Juli 2010
  11. Petteri
    13. August 2009
  12. ColonelZap
    9. April 2008
    Xiaomi Mi4
    Yes, try to rename it. It could be a problem because it has some Chinese charcters in the name.
    This is for a DIFFERENT phone but the flashing process is the same, maybe it'll help as well:
    [ame="http://www.youtube.com/watch?v=-DaHt3OLUos"]YouTube- Sunno Yota Max4G ROM Update - A Merimobiles.com Techtip[/ame]
  13. api29
    api29 New Member
    11. Juli 2010
    Sunno Q880
    Very very thanks the help!!!VICTORY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  14. ColonelZap
    9. April 2008
    Xiaomi Mi4
  15. api29
    api29 New Member
    11. Juli 2010
    Sunno Q880
    HmHm problem!!!The IMEI number: 000000000000000
    It's no normalli.What's problem???
  16. ColonelZap
    9. April 2008
    Xiaomi Mi4
    That's definitely not normal :(
    Is you phone still working anyway? Do you get a signal with your service provider, can you make calls?
  17. api29
    api29 New Member
    11. Juli 2010
    Sunno Q880
    yes it works, but breaks the network from time to time
  18. ColonelZap
    9. April 2008
    Xiaomi Mi4
    I WISH I knew how to get into the "engineer mode" of that phone because then I might have a solution for your IMEI problem. Unfortunately I don't have the slightest clue about how to activate the engineer mode of that phone :(
  19. api29
    api29 New Member
    11. Juli 2010
    Sunno Q880
    I thank you very much for your work!!!
  20. ColonelZap
    9. April 2008
    Xiaomi Mi4
