T5353 G-Sensor question
Dieses Thema im Forum "General Discussions" wurde erstellt von geukster, 23. Januar 2010.
  1. geukster
    geukster New Member
    31. Dezember 2009
    LG
    hello,
    i bought the t5355+ and it works allmost great. The only thing is the gravity sensor. It only works while checking e-mails and text messages. SPB Shell and other programs are not turning with the phone. Does anyone have an clue how to solve this?
    Thanx
  2. huepfehase
    huepfehase New Member
    29. Dezember 2009
    T5353+
    hi,
    if you look at pictures the g-sensor works as well.
    but unfortunately I found no possibility to change the configuration. you can only calibrate it. maybe you need an additional program.
  3. johndebur
    johndebur 迟到总比不到好。
    31. Oktober 2008
    Xiaomi Redmi Note 2 Prime
    Coolpad 9976A
    hello there is an app for everything. :) havent tried it though, the g sensor is still new to me since I only updated the ROM . Just installed a waterlevel .
    But there is a freeware , where you can define what software should rotate. Not sure if it works with spb shell .
    http://www.freewarepocketpc.net/ppc-download-changescreen.html
    there is also this one, but you cant define expetions what software should rotate and what not its just basic:
    http://www.freewarepocketpc.net/ppc-download-rotate-screen.html
    Did install change screen seems to work . ( well the normal Wm 6.5 Manila interface rotates with it now. Can be turned on and off , defintely a nice program )
    Cool added the calculator to the exception list. Now it rotates as well and becomes a scientific calculator :yahoo:
