T5355 GPS problem
Dieses Thema im Forum "General Discussions" wurde erstellt von tantal, 24. Februar 2010.
  1. tantal
    tantal Guest
    I have flash today my T5355 to WM 6.5...and he died :(- black screen. I try 6 softs, everyone was for rev. C02. Phone didn't work with any of them
    Because i don;t make backup of my old wm 6.1, I've start looking for soft C01. And now I'm sure that i have rev. C01, Phone work again with soft C01 :) but in Chinese :(
    Of course GPS and G-sensor still not working.
    Maby someone have wm 6.1 or 6.5 for rev. C01?
  2. rewo
    rewo New Member
    9. Juli 2010
    T5355
    Hi. I have the same problem. Did you manage to fix it and how?
  3. ColonelZap
    9. April 2008
    Xiaomi Mi4
    Is your phone "dead" or are you just having problems with the g-sensor?
  4. rewo
    rewo New Member
    9. Juli 2010
    T5355
    My phone works, but there si no GPS found by BeeLine and g-senzor (acelerometer) is not working.
    Running on WM 6.1. I bought the phone @ merimobiles week ago.
  5. ColonelZap
    9. April 2008
    Xiaomi Mi4
    I never had a GPS problem, have you tried those settings?:
    Program Port: COM6
    Hardware Port: None
    Baud rate: 4800
    check manage GPS automatically.
    About the G-Sensor, have you done all this?
    [ame="http://www.youtube.com/watch?v=Qxi5N5t-vro"]YouTube- The T5355 G-Sensor Setup and Demonstration[/ame]
  6. rewo
    rewo New Member
    9. Juli 2010
    T5355
    I tried this combination (External GPS icon - like it should be) and it is not working. I tried with several GPS programs and seems like there is no GPS reciever:noo:
    [​IMG] BeeLineGPS result.
    [​IMG] when I click on GPS icon.
    There is no G-Sensor icon, only Accelerometer Icon and there I tick options like this:
    ... well nothing happens.
  7. ColonelZap
    9. April 2008
    Xiaomi Mi4
    That's strange :(
    I used to have the WM6.1 version on my phone and I can't recall ever having an accelerometer icon or settings? But I ALWAYS had an G-Sensor icon on it.
    Maybe you have a completely different model than I have?
  8. duffy-31
    duffy-31 Well-Known Member
    3. Februar 2010
    Several User on this Board reporting same Problems with the WM 6.1 English ROM from merimobiles.
    No GPS, no G-Sensor.
    As far is i know the Problem is not solved yet.
  9. rewo
    rewo New Member
    9. Juli 2010
    T5355
    Is there any stable ROM with WM 6.5 for this phone?
  10. ColonelZap
    9. April 2008
    Xiaomi Mi4
    If you have a C02 Hardwareverion, this Rom should work:
    http://chinamobiles.org/downloads.php?do=file&id=182
    You can find out if you have a C2 version, if you find a "+" and "-" in the phone (see picture), also you should have A-GPS settings on your phone.
    If you decide to try this, you are doing it on your own risk!!
  11. rewo
    rewo New Member
    9. Juli 2010
    T5355
    I don't have + & - markings on the phone. It seems like it is older HW version. :(
  12. Petteri
    Petteri Well-Known Member
    13. August 2009
    Tablets: Acer Switch 10
