Teclast P79HD - 2Ghz Intel Atom Z2580 7" FHD 1GB Ram 16GB Rom 699 yuans OTG 3500mah 2/5MP Cams
Dieses Thema im Forum "Allgemeine Informationen/Fragen" wurde erstellt von johndebur, 11. April 2014.
  1. johndebur
    johndebur 迟到总比不到好。
    31. Oktober 2008
    Xiaomi Redmi Note 2 Prime
    Coolpad 9976A
    neues kleines Intel Atom Tablet von Teclast, kostet in CHina 699 yuans (81€)
    首发价699元,台电7寸视网膜屏P79HD登录京东 1pad
    http://www.teclast.com
    http://www.1pad.cn/41974/
    http://item.jd.com/1096244.html#product-detail
    189.jpg 250.jpg nEO_IMG_00001.jpg nEO_IMG_42.jpg rBEhUlNF_Y0IAAAAAAQD6xEEonMAALhcAC-XE8ABAQD004.jpg rBEhVFNF_XYIAAAAAAQOrgxJwwoAALhbQHzMOQABA7G780.jpg rBEhVlNDw64IAAAAAAPW1fFTgTMAALjIAGyU4IAA9bt371.jpg rBEhVlNF_bYIAAAAAAOZ7pN2qxwAALpgAF4VwkAA5oG686.jpg rBEhVVNF_ZgIAAAAAASLUfG22XMAALpfQGCuvkABItp856.jpg rBEhWlNF_d0IAAAAAAUD3fvaaywAALgfgEvnq0ABQP1634.jpg
    Ora sagt Danke für diesen hilfreichen Beitrag.
  2. Ora
    Ora Tester
    22. Februar 2013
    Bluboo S1<- Frau
    Intel, interessant! 3G?
    Gesendet von meinem UMI X2
  3. johndebur
    johndebur 迟到总比不到好。
    31. Oktober 2008
    Coolpad 9976A
    Nee ich denke mal nicht.
    Subject
    Model P79HD
    Color After former White Gold (Tyrant Gold Edition)
    Material / Process The third generation G+ G + tempered glass touch panel nanoscale aluminum metal case
    Time to market April 2014
    Operating system Android 4.2.2
    Configuration
    Storage Capacity 16GB eMMC FLASH
    Processor Clover Trail + flagship Z2580
    Processor Speed 2.0GHz
    System Memory Ultra Low Power Memory 1GB LPDDR2
    Graphics chips PowerVR SGX 544MP2
    Extended Support TF card
    Scalable Capacity 32G
    Show
    Screen Size 7 inches
    Screen Resolution Original 1920 × 1200 screen retina
    Aspect Ratio 16:9
    Screen Type Retina IPS screen
    Screen Description The third generation G+ G tempered glass touch panel
    Pointing device Touch
    Connection
    WiFi function Support
    Built-in 3G Support OTG external 3G card
    3G Type No
    Bluetooth Bluetooth 4.0
    Port
    Audio Interface 3.5mm
    USB Interface Have
    Other interfaces Unique support for Intel WiDi wireless transmission function
    Sound
    Speaker Dual stereo speakers sound chamber
    Microphone Have
    Function
    Camera Supports panorama shooting
    Front camera 2000000
    Rear camera 5,000,000 AF
    Video capture Support
    Multi-touch 10:00
    Movies Support high stream full HD playback
    Gravity Sensor Support
    Light sensor Not supported
    Power supply
    Battery Type Third generation "shaped" lithium batteries
    Battery capacity 3500mAh
    Specification
    Size 191mm (L) × 106mm (W) × 6.8mm (H)
  4. Ora
    Ora Tester
    22. Februar 2013
    Bluboo S1<- Frau
    Bild in 3G? Was ist das?
    Tapa talked
  5. johndebur
    johndebur 迟到总比不到好。
    31. Oktober 2008
    Coolpad 9976A
    lol kein Ahnung.
    In den Kommentaren ist auch einer ratlos, also 3G nur mit nem USB Stecker
  6. Ora
    Ora Tester
    22. Februar 2013
    Bluboo S1<- Frau
    Aber in Deiner Tabelle taucht es in build-in auf. Das mit den Tongle können viele ...
    Tapa talked
    Edit: sehe es gerade ist eine Spaltenbeschriftung :( Tapa kann mit Tabellen nicht umgehen...
  7. johndebur
    johndebur 迟到总比不到好。
    31. Oktober 2008
    Coolpad 9976A
    Ja stand halt auf jd so komisch, habe es nur kopiert. Nicht-built in oder Nix3g wäre da auch verständlicher gewesen :)
