TG-T3 Self-balancing Unicycle auf Deutschland Lager! Nur 244€
Dieses Thema im Forum "Tinydeal.com" wurde erstellt von TinyDeal.com, 2. November 2015.
  1. TinyDeal.com
    TinyDeal.com Active Member Sponsoren
    17. Oktober 2014
    THL, Laude...
      • Revolutionary for personal transportation
      • This is a self-balancing, single wheeled, electric drive high tech vehicle,moreover, the smallest, most convenient and low-carbon vehicle
      • Anytime, Anywhere, At Will Beating a tight schedule? Ride TG-T3, you'll never miss any date nor deadline. With simple operation and sufficient battery range, you're free to enjoy portable and pleasant life!
      • Intelligent Balancing Chip
      • Build-in intelligent balancing chip to maintain balance. Escort your way with fuzzy algorithm & aviation attitude control technique.
      • Built-in 132Wh Samsung lithium battery
      • It is the Self-balancing electric unicycle that can reach up to 18km/h and travel 35km on a fully charged battery, and it only take 30 minutes to charge 80% energy
      • Aviation Aluminum Pedal with Exclusive Pedal Folding Tech
      • High Strength | Ultra-Widened | Suit Your Feet Better Fit | Natural Adsorption | Facilitate Your Riding
      • Low Battery Protection,Speed Control,Tilting Protection
    • It is the most portable vehicle with a built-in carrying handle whose weight is only 10kg that you can easy to carry it on the bus or subway
    • Self balancing gyroscope, automatic correction:
    • -- 1. Fall Back: Body lean back
    • -- 2. Static: Body upright
    • -- 3. Forward: Body forward
    • With small size design that it cannot take up any more space than a briefcase
    • Self-balancing unicycle is composed of super magnetic levitation motor, wear-resisting silicone, aviation aluminum pedal and wear and antiskid tyre
    • Built-in 132WhSamsung lithium battery and it only take 30 minutes to charge 80% energy
    • The Unicycle is easy to learn and intended for adults
    • Note: We provide different colors for your choice
    Product Specifications:
    • Top Speed: 18km/h
    • Max. Distance In One Full Charge: 15km-35km (according to the rider and the temperature)
    • Maximum Gradeability: Approx. 15°-30°
    • Battery: 400W lithium battery
    • Operating Temperature: -10℃-40℃
    • Tilt Protection: 45°(solo wheel will stop working when tilt above 45°)
    • Speed Protection: ≥12km/h(start alerting and automatically slow down if above 12km/h)
    • Low Battery Protection: when battery is lower than 10%, it will slow down and finally stopped working
    • Maximum Load: 120kg
    • Charger Plug: EU Plug
    • Charger Input Voltage: AC220V, 50-60Hz
    • Charger Output: 67.2V, 2.0A
    • Charging Time: Approx.45-60 minutes
    • Tire Size: 14 Inch
    • Information Notice:
    • -- Power switch LED : works when turned on and keeps twinkling under protection circumstances.
    • -- Battery: 4 battery display LED works if battery capacity above 85% and turned off with battery running out
    • -- Voice Alert: Beeps when turned on and has a low battery capacity
    • -- Voice Alert: whistling when tilt
    • Size: 450 x 395 x 160 mm / 17.72 x 15.55 x 6.3 inch
    • Net Weight: 9800 g / 345.69 oz
    Package Contents:
    • 1 x Self-balancing Unicycle
    • 1 x Charger
    • 2 x Crash-proof Tapes (Color Assorted)
