Tiger WG3.
Dieses Thema im Forum "General Discussions" wurde erstellt von leholtet, 29. Dezember 2009.
  1. leholtet
    leholtet New Member
    29. Dezember 2009
    tiger wg3
  2. ColonelZap
    9. April 2008
    Xiaomi Mi4
    Hi :)
    It looks like a standard Chinese OS, based on a necleus OS. Editing Norwegian language will be close to impossible :(
    It should have JAVA, so you can try to install some JAVA apps but the number of working and good apps will be very limited.
  3. leholtet
    leholtet New Member
    29. Dezember 2009
    tiger wg3
    Ok, there are editors here on the forum tough. Im going to try to install Windows mobile on it, does anyone know where i can find the language?
    i mean software :)
    It uses MTK6235
    Zuletzt von einem Moderator bearbeitet: 31. Dezember 2009
  4. ColonelZap
    9. April 2008
    Xiaomi Mi4
    Sorry to disappoint you but it's absolutely impossible to install Windows Mobile on a phone like that :(
  5. leholtet
    leholtet New Member
    29. Dezember 2009
    tiger wg3
    hmm :/ but, i could edit the language right? that has to work in some way?
  6. leholtet
    leholtet New Member
    29. Dezember 2009
    tiger wg3
    i will pay is if someone helps me find a solution :)
  7. Petteri
    Petteri Well-Known Member
    13. August 2009
    Tablets: Acer Switch 10
    hey guy, happy new year at first! if you want to edit language you have to flash mobile phone firmware and this is not so easy in first place you have to find the right one, starting on your phone and this could be strenge! there are so much different fw`s for this kind of OS....the wrong one damages the phone!
  8. leholtet
    leholtet New Member
    29. Dezember 2009
    tiger wg3
    It uses MTK6235 as base. Cant i just copy the firmware of the phone, use language editor, and copy it back on the phone?
    and, Happy new year mate ;)
    Zuletzt von einem Moderator bearbeitet: 1. Januar 2010
  9. leholtet
    leholtet New Member
    29. Dezember 2009
    tiger wg3
    what about android?
