VKWorld VK6735 Review: Better than a Doogee Y100 Pro?
Dieses Thema im Forum "General Discussions" wurde erstellt von zijin_cheng, 12. Oktober 2015.
  1. zijin_cheng
    zijin_cheng Active Member
    8. Februar 2015
    THL 5000
    Cubot X9
    Hey guys, what's up, and this is my review of the VKworld VK6735, a very cheap smartphone that competes with the Doogee Y100 Pro. Is it better than the Doogee? Watch my review to find out!
    ColonelZap und Sotair sagen Danke für diesen hilfreichen Beitrag.
  2. Sotair
    Sotair Kaffes Nikotides
    5. Juni 2015
    Xiaomi RN 3 Pro SE, ASUS Zenfone ZE601 KL
    Thanks a lot for both the review and unboxing vids. Maybe it would be a good idea to provide some basic information and a written summary, too. Maybe in a short + / ÷ neutral / - conclusion like below
    Price: about 109 $
    Specs:
    OS Version: Android 5.1
    CPU: MTK6735 Quad Core
    Processor Speed (max): 1.0 GHz
    RAM: 2GB
    Internal Memory: 16GB
    External Memory: Support up to 32GB
    Display
    Resolution: 1280X720
    Touch Screen: Capacitive, Multi-touch: Support 5 Point
    Network:
    Frequency: 2G: GSM 850/900/1800/1900MHz, 3G: WCDMA 850/900/1900/2100MHz, 4G: FDD:2100/1800/2100/2600
    Other connevtions: GPS, Bluetooth, FM Radio and Portable Wi-Fi Hotspot (3G Tethering)
    Sensors:
    Proximity, Accelerometer, Gravity, Light
    Battery:
    Battery Size: 3000mAh
    Continuous Usage Time: About 4 Hours
    Battery Standby: About 200 Hours
    Wi-Fi: 802.11 b/g/n
    Cams:
    5 Megapixel Front-Facing Camera + 13 Megapixel Rear Camera
    Video Resolution: 640x480 Front / 864X480 Back
    Other Features: Smart Wake, Hotknot
    Ports:
    2 SIM card slot – 1x Micro SIM (WCDMA/GSM/4G), 1x Normal SIM(WCDMA/GSM/ 4G)
    1 Micro SD card slots
    3.5 mm Audio out port
    Micro USB
    Languages: Multilanguage, German supported
    Dim./ Weight: 142 x 72 x 8 mm (L x W x D) // 136g
    Review summary:
    + Good battery life
    + Good baseband reception (2g/3g/4g)
    + Backcover design (just plastic, but good grip)
    ÷ Display quality
    ÷ Performance (Antutu score ~20500)
    ÷ Camera (back 13mp, front 5mp, colors look washed out)
    ÷ Lower midrange SoC, but smooth handling & no lags
    ÷ Mono-Loudspeaker
    - Bad WLAN downstream (should be checked again)
    - Screen to body ratio (fat bezels :))
  3. zijin_cheng
    8. Februar 2015
    THL 5000
    Cubot X9
    That's a great idea. However I am preparing a written review that will go up as soon as i'm done. Thanks for the tip though!
    Sotair sagt Danke für diesen hilfreichen Beitrag.
