Wifi connect pinphone
Dieses Thema im Forum "General Discussions" wurde erstellt von Rayden1980, 11. Dezember 2009.
  1. Rayden1980
    Rayden1980 New Member
    11. Dezember 2009
    pinphone 3gs
    hello, what browser works fine with the wifi pinphone? wap browser does not get this error: Failed to connect
    thanks
  2. SuperSpeMo
    SuperSpeMo Active Member
    25. September 2008
    P168+ Touch kaputt
    (nicht mehr)ZTC ZT5310
    Pinphone 3GS (verkauft :( )
    Zukünftig: HTC Desire Z
    which firmware version do you have?(dial *#1234#)
  3. Rayden1980
    11. Dezember 2009
    pinphone 3gs
    my firmware is I835S_FN_CA_W_V1_0_7
  4. SuperSpeMo
    25. September 2008
    P168+ Touch kaputt
    Build date was the 14.10.2009 right?Sorry,but with this version Java Programs won't work with wifi :(
  5. Rayden1980
    11. Dezember 2009
    pinphone 3gs
    Yes, the date is 14/10/2009 ... and how can I connect by wifi to view web pages?
  6. SuperSpeMo
    25. September 2008
    P168+ Touch kaputt
    Using the internal brwoser gives you an error?bad.I htink you have to wait for ColonelZap ;)
  7. Rayden1980
    11. Dezember 2009
    pinphone 3gs
  8. SuperSpeMo
    25. September 2008
    P168+ Touch kaputt
  9. Rayden1980
    11. Dezember 2009
    pinphone 3gs
    ok I'll wait an answer
    Many thanks!
  10. ColonelZap
    9. April 2008
    Xiaomi Mi4
    Keep in mind that the internal browser is a WAP browser only! Not a "regular" internet (web) browser.
    If you want to connect with the internal browser by WIFI, make sure to have those settings:
    Services - internet service - settings - profiles
    There you need to have your own profile, the only settings that are important there are:
    Data Account: Wireless LAN
    Connection typ: HTTP
    The rest isn't important. Make sure this profile is also activated.
    When your WIFI is on and connected to your router, the internal WAP browser should be able to get connected via WIFI now.
