Yi M1 Review: $330, Better than some DSLRs
Replaces my phone as an event camera!
  1. zijin_cheng
    zijin_cheng Active Member
    8. Februar 2015
    THL 5000
    Cubot X9
    Pros
    • Very strong RAW performance
    • Small, simple
    • Cheap!
    Cons
    • Autofocus not the best
    • JPEGs underwhelming
    This Yi M1 is a $330 mirrorless camera that takes better photos than some DSLRs, no joke. Check out my full Yi M1 review and camera samples down below!
    Yi M1 Mirrorless Camera Specifications:
    Sony IMX269 20MP Sensor
    3" 2 million dot TFT screen
    Kit lens: 12-40mm F3.5-5.6 Lens
    Optional Prime lens: 42.5mm F1.8 lens
    900mAh battery
    0.28kg, 11.35 x 3.36 x 6.43 cm
    Zuletzt von einem Moderator bearbeitet: 10. Januar 2018
