Yophone 4GS Lock Button Problems
Dieses Thema im Forum "General Discussions" wurde erstellt von jonaboy@live.nl, 25. Oktober 2011.
  1. jonaboy@live.nl
    jonaboy@live.nl New Member
    6. September 2011
    Yophone 4Gs
    *sorry for the english but i cant speak german*
    so my problem is that my lock button doesnt work anymore and that my phone is turned off because battery was running low
    maybe someone could please help me cause i cant get it turned on......
  2. Rumpelstilzchen
    21. Juli 2009
    Nexus 5
    Hello :)
    But you should also be able to charge the phone when it is powered off.
    So connect it with the charger for a few hours.
    You should see then a charging symbol on the LCD.
  3. Ciney
    Ciney New Member
    22. September 2010
    Kiphone 4GS
    yes you can charge it when it's off.
    Try pressing home button and lock button for several seconds, may be the phone will boot.
    Is the lock button mechanical broken?
  4. jonaboy@live.nl
    6. September 2011
    Yophone 4Gs
    yes i can charge it and it is a green battery
    and i think the lock button is broken
  5. Ciney
    Ciney New Member
    22. September 2010
    Kiphone 4GS
    okay, so you don't feel any resistance like from a mechanical switch when you press the lock button? Then open the phone and take a look what's broken. If you're lucky the switch is not broken apart from the circuit board but only plastic spring from the button is broken. you can fix this with some glue or by fitting some paper or something like that under button
  6. jonaboy@live.nl
    6. September 2011
    Yophone 4Gs
    thank a lot it worked, but now im facing another problem its that the camera app doenst respond its black and nothing works but 2 mins later it restarts 102_4885.jpg
  7. Ciney
    Ciney New Member
    22. September 2010
    Kiphone 4GS
    try to do a factory reset, the option is in the settings menu. the code is 1122. i hope after that the camera starts again...
  8. jonaboy@live.nl
    6. September 2011
    Yophone 4Gs
  9. kkrriissii
    kkrriissii alter Hase
    25. Mai 2010
    Huawei P10
    Then I think your Camera is broken or your Camera Cable.
    But I don't know how to fix that. It won't be easy to get exactly that spare part that fits into the YoPhone...
