(Gelöst) Probleme bei update doogee turbo dg2014
MonaSteve
habe Probleme bzw. weiß nicht wie ich die mittlerweile zwei updates vom dg2014 auf mein phone bekomme.
Was ist bisher gemacht habe:
Habe mir hier http://www.doogee.cc/en/gb/xiazai.asp?Page=2 beide updates auf meinen PC geladen und unzippt. Meine emmc-Scatterdatei eingefügt und nach dieser Vorlage versucht auf mein phone zu flashen.
[How To] Flash ROM with SP Flash Tool On MTK6595, MTK6592, MTK6589, MTK6572, MTK6582
Flash ROM with SP Flash Tool On MT6595, MT6592, MT6589, MT6572, MT6582, MT6577
If you’d like to know how to flash a ROM on MT6595, MT6592, MT6589, MT6572, MT6582, MT6577, you’re on the right post. Normally we refer people to a rooting post, which includes this information, as the procedure is mostly the same. But for the sake of simplicity, we’ll write a stand-alone tutorial.
Note, if you don’t have access to a backup, create one first -
Remember, we ARE NOT responsible for any hell that happens to your phone. You take any and all responsibility for messing with your phone.
What you’ll need:
•MTK / MediaTek based smartphone
•USB Data Cable
•USB ADB VCOM drivers
•SP Flash Tool
•MTK Droid Tools (if scatter not included with ROM)
What to do:
•Step 1 – Install the PDANet USB ADB VCOM drivers -
•Step 2 – Download, extract, and run the latest version of SP Flash Tools
•Step 3 – Check to see if a scatter file exists. Look in the firmware / ROM’s folder. You should see a file that looks similar to ‘MT6582_Android_scatter_EMMC.txt’. If you don’t see the scatter file, you need to create one with MTK Droid Tools. After you’ve created the scatter, place it in the same folder as the firmware / ROM you intend to flash.
•Step 4 – Select ‘scatter-loading’ from upper-right of SP Flash Tools. Navigate to the ROM / Firmware’s directory and you should see a file that looks something like MT6582_Android_scatter_EMMC.txt. Select this and you should then see a checklist of different parts of the ROM load in the bottom portion of SP Flash Tools.
•Step 5 – Deselect ‘preloader’ in the checklist. If you don’t want the firmware / ROM to mess with your current partitioning, deselect EBR1 and EBR2 as well. NOTE: If you’re sure you have the correct firmware for your phone, you can leave Preloader selected.
•Step 6 – Make sure the phone is disconnected from USB and powered off. Select ‘download’ from the top of SP Flash Tools. NOTE: If all portions of the firmware are checked, then you can select ‘Firmware Upgrade’. If you have problems with ‘Firmware Upgrade’ or vice versa, you can try the other one.
•Step 7 – Connect USB cable to phone and watch the pretty colors fly
Ich habe die Variante mit und ohne Preloader als download und firmware upgrade versucht. (Mit Preloader s. Anhang)
Bei der Variante download ohne Preloader ist mir aufgefallen, dass der "lila Balken" nicht erscheint.
Trotz alledem, ich kann machen was ich will, phone hängt sich nach logo auf.
In den Recovery-Modus gelange ich nicht. Da liegt dann nur ein Android-Männchen mit roten Ausrufezeichen auf dem Rücken.
Ich weiß nicht was ich falsch mache. Vlt. kann mir jemand sagen, was ich falsch mache und wie ich die updates auf's phone bekomme.
dorschdns
ClonePhone Facharzt
aus diesem Grund solltest du mal bitte mein Recovery, welches ich gestern hochgeladen habe statt deinem flashen.
Bei deinem handelt es sich um das Stock Recovery, meins ist aber ein CWM Recovery.
MonaSteve
:party:
Es ist vollbracht. Beide Updates nacheinander auf's Phone gezogen. Es es läuft:Mauridia:
Und was soll ich sagen. Die Camera ist wesentlich besser als vorher. Füge mal zwei Bilder zum Vergleich an.
MonaSteve
Ich habe eigentlich nicht viel anders gemacht, als oben beschrieben. Außer, dass ich mit SP FlashTool Version V3.1344.0.s.n212 über Firmware Upgrade geflasht habe.
Danach wie oben für 15 Min. nix. Akku raus und versucht ins cwm zu kommen. Ging wie oben auch nicht. Über SP FlashTool meine recovery.img eingespielt und ins cwm gebootet. Dort dann - wie mir bereits empfohlen wurde - "wipe data/factory reset" gemacht, ins recovery gebootet. Und jetzt läuft es.
Eine andere Erklärung kann ich dazu leider nicht geben.
Daemonarch
Chiclone-Lover
Ich glaube aber, du hättest gar nicht beide firmwares downloaden und flashen müssen, die neuere hätte gereicht.
Auf jeden Fall super, wenn die so die Kamera verbessert! :thumb_up:
Daemonarch
Chiclone-Lover
Hast du mal versucht mit der neuen Firmware drauf das Phone zu rooten?
Ich verzweifele nämlich gerade daran.
MonaSteve
Hatte Root in der Shell nach Methode von tommy0815 erlangt.
Dann kam bei mir nen komischer Kamerafehler. Wenn ich Fotos machen wollte, hatte ich nur nen grünen Screen.
Also habe backup eingespielt = Kamera läuft wieder - grüner Screen weg.
Update eingespielt = Kamera läuft immer noch.
Root eingerichtet = Kamera wieder grüner Screen.:ireful2:
Werde jetzt nochmal updaten und dann berichten.
MonaSteve
Allerdings...
... und nochmal nach Methody tommy root gehabt und Kamera wieder grün.
Ich werde jetzt nochmal update einspielen und erstmal nicht mehr versuchen root zu bekommen. Mal sehen, ob es bei der funktionierenden Kamera bleibt.[DOUBLEPOST=1399194373,1399192869][/DOUBLEPOST]@Deamonarch: wie hast Du Dein Update denn letztlich drauf bekommen? Würde mich mal interessieren.
Daemonarch
Chiclone-Lover
Hab erstmal mit den Droidtools ein backup erstellt, und dann dessen Scatterfile zum flashen benutzt.
Beim ersten flashen hab ich preloader, uboot und userdata weggelassen - da bootete es in einen screen wo was von "encryption failed" oder so stand, ging nicht weiter.
Dann hab ich noch uboot und userdata nachgeflasht, dann bootete es in den "android-krank" recovery screen, und sagte was von "system kann nicht gemountet werden und muss gewiped werden"... Das tat es dann automatisch, und fuhr danach normal hoch.
Daemonarch
Chiclone-Lover
Wie kann den Root derartig in die Treiber eingreifen, und warum ging es mit der alten Firmware problemlos?
MonaSteve
Habe diese Schritte durchgeführt:
DroidTools geöffnet
Handy per USB an PC angeschlossen und Reiter "root, backup, recovery" angeklickt
Recovery and Boot (To choose the boot.img file) gedrückt
im Flash Tool ausgelesene ROM_boot.img geöffnet und CWM automatisch erstellen lassen
Flash Tool geöffnet
meine Scatter geladen, Haken bei boot und bei recovery gesetzt, Handy ausgeschaltet und Akku raus, Download gedrückt
Akku wieder rein und Handy PC angeschlossen, Flashprozess läuft durch bis grüner Kreis.
DroidTools gestartet, Handy wurde erkannt und unten links war "grün"
dorschdns
ClonePhone Facharzt
Hmm... Ich dachte immer recovery und boot.img wären bei den mtk's zwei getrennte Dinge.
das sind es auch.
wenn du das root in der shell mit den MTK Droid Tool erstellen lässt wird ein boot image gepatscht.
Dieses mußt du dann auch mit dem neuen boot image machen lassen, ich vermute, dass hier nur das alte boot image aufgespielt wurde um root zu erlangen.
Daemonarch
Chiclone-Lover
Wenn ich also ein cwm-recovery pur installiert kriegen würde, liesse sich dadurch auch ein root-zip flashen?
Braucht man da was 6582 spezifisches?
